LA-J801P schematic (Acer A315-56)
  • reformatt
    • Feb 2020
    • 1505
    Anyway have this one before I put money down (again) at Vinafix?
    Have a shorted cap on the +5V JW505068C regulator IC (from liquid damage) just don't know its value. The datasheet seems a bit scarce on detail from the manufacturer.
  • reformatt
    • Feb 2020
    • 1505
    Re: JA-801P schematic (Acer A315-56)
    Can't edit this so apologies in advance. It's a LA-J801P motherboard (doh).
    There are two caps shorted, one on pin 15, the other pin 16/17. It appears from this datasheet these are 4.7uf and 2.2uf respectively. Although titled EV5086C, it refers to JW5086C and the pinouts look identical.
    https://cdn.badcaps-static.com/pdfs/...c81d1afb15.pdf
      • 21922
      Re: LA-J801P schematic (Acer A315-56)
      Schematic + Boardview. Not sure if the schematic is legit,the cover page says LA-J801P, the other pages are LA-H801P and LA-H791P
      • PC-R TECH
        PC-R TECH commented
        Editing a comment
        Thanks bro
      • 21922
      Can you post a picture of the JW505068C
      • drhardware2022
        • Jan 2022
        • 15
        • Chincha
        Thanks Man
        • redman13
          • Aug 2016
          • 66
          • bangkok
          Thank you
          • doktorkomputer
            • Aug 2016
            • 66
            • Poland
            Thx
            • javo
              • Mar 2022
              • 30
              • argentina
              gracias Thanks!
              • Iceberg149
                • May 2020
                • 12
                • Ukraine
                Thank you!
                • tipin45
                  • Jan 2011
                  • 15
                  Thank you
                  • shaon_kof
                    • Feb 2014
                    • 41
                    • Bangladesh
                    Thanks a lot.
                    • siroos_tz
                      • Feb 2014
                      • 121
                      • the UK
                      Thanks a lot
                      • joaquinmjuan
                        • Sep 2014
                        • 31
                        • España
                        Many Thanks!!!!
                        • maybepanic
                          • Jul 2021
                          • 4
                          Thank you very much
                          • supersbg
                            • Feb 2018
                            • 14
                            • България
                            Thank you.
                            • helbertapple
                              • Mar 2022
                              • 6
                              • brasil
                              top
                              • mentofenol
                                • May 2021
                                • 6
                                • Portugal
                                Hello!
                                Also about this motheraboard, could someone help me identifying a smd chip MESC5V02BD03_SOT23-3 which has inscrit on it L5B, to try to find an equivalent or compatible one?
                                Included i attach some pitures.
                                Thank you in advance.
                                • ilmagnofranco
                                  • Aug 2023
                                  • italy
                                  Hello. which software can open the schematic?
                                    • 21922
                                    OpenBoardview - https://www.badcaps.net/forum/showthread.php?t=54661
                                    Or BoardViewer - http://boardviewer.net/
                                    • doktorkomputer
                                      • Aug 2016
                                      • 66
                                      • Poland
                                      Originally posted by smdflea
                                      schematic + boardview. Not sure if the schematic is legit,the cover page says la-j801p, the other pages are la-h801p and la-h791p
                                      thx
                                      • atunguyd
                                        Acer x163w Monitor PSU schematic
                                        by atunguyd
                                        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                        03-05-2025, 02:08 PM
                                      • wasyl
                                        Acer Nitro AN515-46 HH51R LA-M002P R1A BoardView File + schematic
                                        by wasyl
                                        Hi, did not found here so uploading to help...
                                        09-15-2025, 07:40 AM
                                      • Proxy64
                                        Looking for Acer Predator 17 G9-793 (N15P4) schematic
                                        by Proxy64
                                        Hi, I am looking for schematics for an Acer Predator 17 G9-793-73A6?
                                        I can not read the last digit, maybe 6.
                                        In another topic I found a boardview that seems to match mine: Acer Predator 17 G9-793 - Pegatron MU5DC CH7DC BoardView
                                        But in the same topic schematics don't match (both board view & mine) : Acer Predator 17 G9-793 - Pegatron MU5DC CH7DC REV 2.0
                                        On this mainboard, the GPU is dead (shorted), but I am trying to have it booting without the GPU Nvidia, to disconnect GPU I have desolder 3 coils powering the GPU, and one bigger in upstream these 3.
                                        Now it begin...
                                        06-05-2025, 09:30 PM
                                      • ARKADII KAPLAN
                                        boardview schematic for acer DAZAWMB18B0 motherboard.
                                        by ARKADII KAPLAN
                                        Hi there all, Merry Christmas and Happy New Year!
                                        Looking for advice, Need to restore/fix the damaged Acer Aspire 514 -54 power circuit pathways.
                                        I am not good at reading schematics and have difficulty finding the board viewer schematic or simple schematic for damaged parts, but I have all the tools and experience for micro-soldering. All I need to figure out is which ends (from-to) and trace wires to restore lines.
                                        Hope the pictureS are clear enough to see the problem...
                                        01-05-2025, 03:57 AM
                                      • Quang Khánh Chu
                                        Acer Swift Go 14 laptop schematic
                                        by Quang Khánh Chu
                                        Dear all!
                                        I need the schematic of Acer Swift Go 14 IH4ST LA-M721P. Can someone help me?
                                        07-24-2025, 11:32 AM
