Asus eeePC 1225B
  • Bonzas
    • 469
    • Indonesia
    Asus eeePC 1225B
    Hello sir, i need guide repair this board.
    This board was totally dead, user tell that board repair from another store but they gave up. after tracing some voltages, found that charging ic and some caps short. After replace some short component. laptop turn on and battery charging. The problem is, laptop won't turn on with battery only, battery is charged 100%.
    maybe someone can help share clear picture on battery connector & ic charging area ?
    - IC charging = ISL88731C
    Thank's
  • Lexus233
    • Jan 2019
    • Россия
    It may be useful to anyone
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • johnbeton
      Asus X415EA not charging battery
      by johnbeton
      I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
      So far I measured all the pins on the bq24780s controller with the following result:
      1. ACN = 0.0V
      2. ACP = 19.02V
      3. CMSRC = 18.5V
      4. ACDRV = 23.9V
      5. ACOK = 5.9V
      6. ACDET = 2.57V
      7. IADP = 0.17V
      8. IDCHG = 0V
      9. PMON = ?
      10. PROCHOT = 5.05V
      11. SDA = 3.3V
      12. SCL = 3.3V
      13. CMPIN = 0.47V
      14. CMPOUT = 6.0V
      15. BATPRES = 0.0V
      16....
      05-19-2025, 04:05 AM
    • thomasmagic
      not charging asus g531gw 1.6
      by thomasmagic
      hello,
      if you can help me, i have mainboard asus g531gw Rev 1.6 with short and no power
      i have found short on C3907 (PVDD_AMP) and remove it
      Actually machine works but battery is not charging. I have test with new one and i have too replace BQ24780S (charging IC) and same problem.
      It's not 1st time when i remove short after the battery is not detect
      On mybook i know we can make jumper beetween two lines for recognised this one
      do you have solution for pc and actually this mainboard? Thanks for your help ...
      06-19-2025, 12:54 PM
      ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
      This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
      09-07-2024, 02:50 AM
      ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
      This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
