Macbook pro M1 A2338 820-02020 schematics boardview
  • mferna14
    replied
    Re: Macbook pro M1 A2338 820-02020 schematics boardview
    Originally posted by DerekChen65535
    I have fixed the issue above in BVR.
    "DerekChen65535" you guys are fixing all these issue, but inform us how & in what program to use it. How are you guys viewing it???
  • mferna14
    replied
    Originally posted by whizkidz
    Finally finished the task of creating the board view file and cleaning the schematic pdf
    So if you find any error please reply here and will see if a can and/or want to correct them. ( 1 SIDE NOTE the ic UP102 and components are not on the actual board but are there to connect the signals)
    So enjoy the hard work.
    Great work, but how to use it (820-02020_V1.1.BVR) dear, it gives errors when I open on "OPENBoardView"... Pls. inform me how did you guys manage to view it. Thanks in advance
  • mferna14
    replied
    Hi Piernov., why am I having problem opening the .brv extension files. I needed the boardview for Macbook pro M1 A2338 820-02020, but the boardview file is in .brv format. Can you please inform me how to OPEN this extension. Thanks in advance
  • burkancho
    replied
    Did you know some one why can I open the BVR file Which openboardview
  • pkk2
    replied
    thanks
  • Joztu
    replied
    Originally posted by DanielAlMasri
    820-02020_V1.0.BVR
    how to open .BVR file for BoardView? please
    Download openboardview (free)
    I use openboardview though and it works great too
  • yustaff
    replied
    Thank you very much
  • Pinoflex
    replied
    thanks
  • DanielAlMasri
    replied
    820-02020_V1.0.BVR
  • mobilesolution
    replied
  • pacwcbs
    replied
    Thank you
  • Deluccia
    replied
    Thank you so much this is absolutely fantastic.
    The people on this platform are a great asset to the progress of the industry.
  • cloudmaxcochin
    replied
    thank you so much
  • hmoreno
    replied
    thank you
  • Rashid36
    replied
    Thank you Dear
  • WispN
    replied
    TY Wiz!
  • pacwcbs
    replied
    Thank you.
  • piernov
    replied
    https://github.com/OpenBoardView/Ope...ases/tag/9.0.3
  • jovan_kineas
    replied
    it can't be opened with open board view 8.0, i tried it with all the files you have placed
  • Instafixx
    replied
    Hello All,
    Namaste from Indian.
    How to view the Board View File ? its a .brv extension.
    Apple MacBook Pro M1 A2338 820-02020-A Boardview
    Apple MacBook Pro M1 A2338 820-02020-A Boardview...
    10-22-2024, 02:25 AM
  • CG_Dionysos
    MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
    by CG_Dionysos
    I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
    • Model: A1707
    • 15-inch, Mid 2017
    • 3.1 GHz Core i7
    • 16 GB RAM
    • Radeon Pro 560
    • 1 TB SSD
    • Board number: 820-00928-A
    I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
    Thanks in advance!
    Greetings from Germany...
    09-16-2025, 06:43 AM
  • Orux
    Macbook Pro M1 A2338 13"
    by Orux
    I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
    I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
    One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
    09-22-2025, 12:54 PM
  • sdogs
    macbook pro M1 a2338 no video on internal display PP3V3_S2 short
    by sdogs
    Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
    First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
    I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
    06-27-2025, 01:58 PM
  • sdogs
    by sdogs
    06-27-2025, 11:26 AM
