plz i need schematic for Hp EliteBook 745 G4
			by romkyHello guys,
 Need schematic or/and boardview for HP Elitebook 850 G8 6050a3216701-mb-a01(a1).-
			by Henning HøyHello everyone,
 Today, I received an HP EliteBook 640 G10, DA0X8TMBE0 Rev: E.
 I have examined it under my microscope and unfortunately, there are several components on the motherboard (water damage) that need to be replaced. Does anyone here have the schematic & boardview for this model?
 Thanks in advance.
 Best regards,
 Henning
			by PacoGThello firends
 i search the schematic or boardview
 I have this motherboard, but I can't find the schematic or the boardview.
 The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
 So the computer doesn't turn on, and the 3V disappears after a few seconds.
 The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
 The new problem arose after removing the bad chip.
 3V and 5V remained together,...-
 08-19-2025, 08:25 PM
			by re-atariHello all,
 Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
 This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
			by jonyhdtvHP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
 Looking for schematic and boardview
 Model: HP ProBook X360 11 G3 EE
 Serial: SCG9114JG7
 Motherboard: L43774-601
 defect: touchscreen doesn't work (touch works on another computer)
 thanks to all-
- Loading...
