Schematic & boardview for HP EliteBook 640 G10 - DA0X8TMBE0 Rev: E
  • Henning Høy
    • Mar 2024
    • Denmark
    Today, I received an HP EliteBook 640 G10, DA0X8TMBE0 Rev: E.
    I have examined it under my microscope and unfortunately, there are several components on the motherboard (water damage) that need to be replaced. Does anyone here have the schematic & boardview for this model?
    Thanks in advance.
    Best regards,
    Henning
  • DimaWari
    • Oct 2022
    • 8
    • Philippines
    I need this also. Thank You.
    • Blyth Doctor
      • Dec 2023
      • 7
      • Senegal
      hi how are you haven't always found the diagram or the boardview. Thanks
      • romky
        HP Elitebook 850 G8 6050a3216701-mb-a01(a1) Need schematic or boardview.
        by romky
        Hello guys,
        Need schematic or/and boardview for HP Elitebook 850 G8 6050a3216701-mb-a01(a1).
        01-30-2025, 08:34 AM
      • AustinCER
        In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
        by AustinCER
        I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
        No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
        There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
        Any insight, schematic or boardview would be greatly appreciated.
        Model: Lenovo Ideapad Flex 5 14ALC7...
        Yesterday, 03:49 PM
      • PacoGT
        HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
        by PacoGT
        hello firends
        i search the schematic or boardview
        I have this motherboard, but I can't find the schematic or the boardview.
        The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
        So the computer doesn't turn on, and the 3V disappears after a few seconds.
        The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
        The new problem arose after removing the bad chip.
        3V and 5V remained together,...
        08-19-2025, 08:25 PM
      • hosain0489
        Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
        by hosain0489
        I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
        Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
        If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
        Thank you very much in advance!
        07-15-2025, 11:20 AM
      • re-atari
        Gigabyte GA-H110-D3A schematic/boardview needed
        by re-atari
        Hello all,
        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
        02-24-2025, 06:45 PM
