X441NC rev 2.2 schematic?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hope someone has a schematic or a boardview anything that will be agreat help to my repair of this unit .
  • chumy
    • Mar 2012
    • 23
    • indonesia
    Re: X441NC rev 2.2 schematic?
    up
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      I found a brd but its not downloadable you need to download a software and its trials 3 days only enought to trouble shoot the laptop
      http://global.wmdang.com/index/index....html?chinafix
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Just register and download the software then search the board number
        • dhs6512
          • Oct 2019
          • 38
          • Литва
          Boardview
          • rzarama
            rzarama commented
            Editing a comment
            Muchas gracias
        • Andyservo
          • Jun 2013
          • 152
          • Indonesia
          Originally posted by dhs6512
          Boardview
          Thank you for this Sharing...
          • Bayu Artha
            • Oct 2017
            • Indonesia
            jejak, thank's
            • juannnn
              • Nov 2023
              • mexico
              muchas gracias brio
              • Macias
                • Nov 2019
                • 83
                • Ecuador
                Boardview
                Thank you
                • zen
                  PS48 Bose sub & head unit schematic / advice please.
                  by zen
                  PS48 is model for sub & where i suspect issue lies .
                  CD head unit seems to run ok , & can take a line out signal into an amp with audio present .
                  Can't seem to measure any voltages at secondary side of PSU within SUB unit ....
                  07-08-2022, 07:53 AM
                • TinkerTron
                  Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                  by TinkerTron
                  Hey everyone,
                  I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                  Instead, here's what's been bugging me so far:
                  The schematic...
                  03-06-2025, 02:03 PM
                • atunguyd
                  Acer x163w Monitor PSU schematic
                  by atunguyd
                  Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                  The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                  03-05-2025, 02:08 PM
                • ngml
                  Repair of an LG split AC system indoor unit PCB
                  by ngml
                  I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                  This indicates an error in the communication between the outdoor and the indoor unit.
                  The outdoor unit is fine, so the problem is the indoor PCB.
                  The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                  I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                  Does anybody have the schematics of this board,...
                  02-01-2025, 12:55 PM
                • Thetechdude
                  MSI Ventus RTX 4080 16G Broadview schematic needed
                  by Thetechdude
                  Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                  I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                  Thanks.
                  07-15-2025, 11:15 AM
