Lenovo C930-13IKB EYG70 NM-B741
  • jimanez11
    • Jan 2015
    • 93
    Anyone have a schematic / boardview for a Lenovo C930-13IKB EYG70 NM-B741. Any help is appreciated!
  • TranaRiparDis
    • Mar 2021
    • 18
    Re: Lenovo C930-13IKB EYG70 NM-B741
    Me too I need the schematic for this laptop. What's the problem with yours ? mine doesn't charge at all.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      NM-A741 is freely available. Does it matches??
      • TranaRiparDis
        • Mar 2021
        • 18
        unfortunately, it's not the same
        • TranaRiparDis
          • Mar 2021
          • 18
          My first contribution
          had to buy it
          enjoy
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Thanks for sharing.
            • chaz brandon
              • Jun 2020
              • 27
              • Uganda
              thank you
              • jimanez11
                • Jan 2015
                • 93
                You're the best! Thanks for sharing TranaRiparDis! And apologies for the late response - had a little girl join the family about a week and a half ago, so have been a bit preoccupied.
                • jimanez11
                  • Jan 2015
                  • 93
                  Mine is having the same issue - no charge and no LED indicator on the board when a known good charger is used. So basically no response what-so-ever on this board, which may make for an interesting repair attempt. Let me know what the result of yours is and I will do the same - thanks again for sharing.
                  • heta1000
                    • Jul 2013
                    • 33
                    • egypt
                    thanx alot
                    • Computercenter
                      • Aug 2021
                      • The Netherlands
                      Im having the same issue, i have discovered part PU22 to be shorted, puts out a lot of heat when charger is connected. maybe that helps.
                      • c0vert
                        • Mar 2022
                        Thanks for the schematic. So far diagnosed U37 as getting hot. No charging. Draws 350mA @ 5V on the usb-c
                        • jimanez11
                          • Jan 2015
                          • 93
                          Have fixed two of these with the same issue. One of the 4 power filter caps to the right side of PR50 was shorted. They are shown as PC77, PC78, PC79, and PC80. I removed all four of these, replaced one with a dead short across it, and machine booted perfectly.
                          If this is happening, a decent way to test would be to check for a fault on U227 or U38. These IC's have a fault detection pin (from what I remember) and will cycle in a specific way if there is a short on the output line. Ill see if I can dig up a data sheet for them, but its a APL3572 chip.
                          • c0vert
                            • Mar 2022
                            With the advice on this thread https://www.badcaps.net/forum/showth...highlight=c930 I believe my Cypd4226 (U36) is also at fault.
                            U37 reg is getting hot for me. 2.7V on it's output when Type-C plugged in and about 5 ohm's between GND and VOUT on U37 and GND and V3P0_CCG4_VDDD.
                            I removed U36 and now seeing hundreds of ohm's on V3P0_CCG4_VDDD to GND.
                            I've ordered a new Cypd4226.
                            I've been able to boot the laptop with the battery in using 7.6V on PF5. This should allow me to flash the firmware using the lenovo tool into the Cypd chip. It's currently drawing 2.6A as it charges t he battery.
                            I'll be back later this month with news when the new cypd arrives.
                            • c930bricked
                              • Sep 2022
                              • israel
                              yoga c930
                              I am looking for the schematics of Levono Yoga c930 13-IKB Mother Board NM-B741 EYG70 Ariel-SVT.
                              Part description: MB L 81C4 WIN I7-8550U UMA 16G.
                              Part number: 5B20S72101.
                              Thank you.
                              • PMDev
                                • Oct 2023
                                • 17
                                If somebody need boardview, here you have it. Enjoy!
                                • mrkmpn
                                  Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                                  by mrkmpn
                                  Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                                  This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                                  03-13-2024, 01:54 PM
                                  Lenovo 3000 Series Schematic
                                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                  3000 C100 laptop with Braille keyboard
                                  Lenovo 3000 C
                                  C100, C200 - 15-inch XGA screen
                                  Lenovo 3000 N
                                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                  N500 - 15.4 inch screen.
                                  Lenovo 3000 V
                                  V100, V200 - 12.1-inch WXGA models
                                  Lenovo 3000 G
                                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                  10-04-2024, 06:05 AM
                                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                  09-06-2024, 06:40 AM
                                  This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                  09-06-2024, 06:06 AM
                                • derradji89
                                  Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                  by derradji89
                                  Hi everyone 🤗
                                  I have a Lenovo MIX 320-10lCR computer.**
                                  1. **Operating System**: Windows 10 ** Education** 64-bit.
                                  2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                  3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                  4. **BIOS Chip Reflashing**: Currently,...
                                  04-19-2025, 03:04 PM
