Hp 14 ck0989na
  • lewis912
    • Oct 2020
    • uk
    Hp 14 ck0989na
    Please i need the schematic for college
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp 14 ck0989na
    Mb marking???
    • lewis912
      • Oct 2020
      • uk
      Re: Hp 14 ck0989na
      14-std-glk
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: Hp 14 ck0989na
        GRANGER-It's available only on paid sites.
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • atunguyd
          Acer x163w Monitor PSU schematic
          by atunguyd
          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
          03-05-2025, 02:08 PM
        • Thetechdude
          MSI Ventus RTX 4080 16G Broadview schematic needed
          by Thetechdude
          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
          Thanks.
          07-15-2025, 11:15 AM
        • ianpoultonknights
          Zenbook Flip 15 UX562AI schematic
          by ianpoultonknights
          Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
          06-26-2025, 02:41 PM
        • kodox
          ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
          by kodox
          since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
          the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
          what i've done:
          - flashing...
          12-29-2024, 02:49 AM
