I need schematic and boardviwe dell inspiron 15. 3473-3573,vegas.turis 17831-1
Re: Schematic request.
Dell Inspiron 3473/3573 and Vostro 3572Attached FilesComment
Re: I need schematic and boardviwe dell inspiron 15. 3473-3573,vegas.turis 17831-1
I need schematic and boardviwe dell inspiron 15. 3473-3573,vegas.turis 17831-1Comment
It was a 17841-1, not 17831-1. can help to find 17831-1 schematic diagram?Comment
855 downloads and it took two year for someone to figure out that the schematic is completely different.
I couldn't locate a schematic for this in paid sites either. All are renamed schematic for Vegas_Turis Kabylake and Skylake versions. If you can find a link for proper schematic, send in PM (as links to commercial sites are prohibited). I will try to get it.Comment
try this boardviewComment
DELL Vostro 3450 / Dell Inspiron 14R N4010 DAV02AMB8F1 Schematic & Board View...
Channel: Schematics and Boardviews
Need schematic diagram and board forms for dell Inspiron 14 5401/5408...
Channel: Schematic Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by watchkeepIt's a schematic diagram, pdf, I have found both the bitmap and PCB wiring diagram, but there is no schematic diagram. They are all reversed, and I cannot find the chip data manual yet
by atsioLooking for the boardview/schematic of the Dell Inspiron 14 7425 2-In-1 Series, mainboard Wistron Antman 14 AMD UMA 213084-SC.
Thanks in advance-
11-06-2024, 10:18 AM -
- Loading...
thank you
