eg430 nm-b731 rev 1.0 schematic
  • Prabuth
    Technician
    • Sep 2018
    • 78
    • Sri Lanka
  • Mazorca
    • Jan 2017
    • 463
    Re: eg430 nm-b731 rev 1.0 schematic
    I also need this schematic, PU401 is burned, marked with AWKAI.
      • 21936
      No schematic available yet.Post a good clear readable picture of PU401
      • Mazorca
        • Jan 2017
        • 463
        I downloaded the schematic for Lenovo Ideapad 330-14ISK, which is very similar to what I have, Lenovo Ideapad 330-14IKB although different board numbers. Looks to be a SY8286BRAC, a 6A, 23V step down regulator. It even had the same device numbers. Found it on ebay, well it will take a month to repair. Thank you for your concern.
          • 21936
          Yes,its AWV not AWK . SY8286BRAC
          https://www.badcaps.net/forum/showpo...23&postcount=1
          • kodox
            • Jul 2017
            • 329
            • Indonesia
            can you share downloaded schematic (Ideapad 330-14ISK)? i need to troubleshoot Ideapad 330-14IKB
            • ianlouievargas
              • Sep 2022
              • 10
              • Philippines
              LOOKING FOR SCHEMATIC AND BOARDVIEW FOR EG430 NM-B731
              THANK YOU ADMIN
              • AL._.EX
                • Dec 2022
                • 896
                • Belarus
                Schematic & boardview
                • ianlouievargas
                  • Sep 2022
                  • 10
                  • Philippines
                  thankyou
                  • bad gofar
                    • May 2025
                    • Indonesia
                    THANKS SIR
                    • mhenapz
                      eg430 nm-b731 schematic
                      by mhenapz
                      need schematic for eg430 nm-b731 schematic, any one can help me?...
                      09-22-2022, 09:11 AM
                    • TinkerTron
                      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                      by TinkerTron
                      Hey everyone,
                      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                      Instead, here's what's been bugging me so far:
                      The schematic...
                      03-06-2025, 02:03 PM
                    • atunguyd
                      Acer x163w Monitor PSU schematic
                      by atunguyd
                      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                      03-05-2025, 02:08 PM
                    • Thetechdude
                      MSI Ventus RTX 4080 16G Broadview schematic needed
                      by Thetechdude
                      Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                      I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                      Thanks.
                      07-15-2025, 11:15 AM
                    • ianpoultonknights
                      Zenbook Flip 15 UX562AI schematic
                      by ianpoultonknights
                      Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                      06-26-2025, 02:41 PM
