I need a schematic on this hp 14 6050a3063701-ma-A01 ASHMORE please
hp 14 6050a3063701-mb-A01 ASHMORE need schematic
Re: hp 14 need schematic
ma-A01 - MB-A01 -
Its not available .Comment
@smdflea since schematic is not available, I need help on this the problem is soy sauce damage the switch board is shorted and broken ribbon cable, i just want to know the switch on the KBC ITE8987E to power onComment
Every donation made will go towards server fees and maintenance costs.Comment
I check on datasheet i cannot find where is the pins to short to ground to turn onComment
Still cannot figure out on IT 8987e the switch to power on the laptop can anyone help on this pleaseComment
Short the pins at the connector. Measure voltage at connectorComment
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by atunguydIi wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...-
Channel: Schematics and Boardviews
by SdhjmI'm asking if anyone has a schematic for the dag3pmb18b0 rev:b g3p board. I found a schematic of the board, but I don't have the component numbers. If anyone needs a schematic, I can send it to you, but I don't have the numbers....
Channel: Schematic Requests ONLY!
11-26-2025, 03:43 AM -
by ThetechdudeHi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
Thanks.-
Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
06-26-2025, 02:41 PM -
- Loading...
