Asus UX303U schematic
  • PinGuy
    • Oct 2016
    • 74
    • Argentina
    Checking this laptop, coffee damaged, 5V to HDD missing, and coolers won't spin at all, need to follow the path to voltages. Hope it is available, thanks in advance.
    • 21582
    Re: Asus UX303U schematic
    https://www.badcaps.net/forum/showthread.php?t=79842
    • PinGuy
      • Oct 2016
      • 74
      • Argentina
      After cleaning up all the mess, a very tiny 100k resistor at PR8823 was missing, and it feeded the gate of the 5V mosfet at PQ8801, so that was the fault.
      @SMDFlea Thank you thank you thank you very much!!!
      • LarrySabo
        • May 2015
        • 29
        Hello PinGuy,
        Did you manage to find a schematic for this MB? I have been unable to find one. Couldn't open the boardview file either using the latest version of the Fritzing program; I'm getting the following error:
        Parse error (1) at line 1, column 1:
        error occurred while parsing element
        D:\WPDOCS\Business\Laptop Boardview Software and
        Boardviews\UX303UB_2.0_60NB08U0-MB1410.fz
        I'll contact Fritzing tomorrow to pursue that but would appreciate any leads on a schematic if anyone has any.
        I stupidly neglected to disconnect the battery before disconnecting and reconnecting the LVDS cable so blew something. <Sigh>
        • mon2
          • Dec 2019
          • 14631
          Try the attached for your .fz files.
          • LarrySabo
            • May 2015
            • 29
            Thanks @mon2! My Av quarantines that but I'll try to make an exception. Any suggestions re. schematic?
            Edit: Works great -- thanks!
              • 21582
              You can use openboardview as well, with the fz license key added. https://openboardview.org/
              • khabib
                ASUS STRIX G531GT MISSING PM_SLP_SUS#
                by khabib
                Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
                here what i measure already:
                EC_RST# 3.3V
                SRTCRST# 3v
                +3VA_RTC 3V
                RTCRST# 3V
                ME_SusPwrDnAck 0V
                AC_PRESENT 3.3 V
                AC_IN_OC# 0V
                PS_ON 3,3V
                +3VA_DSW 3.3V
                DPWROK_EC /R 3.2V
                PM_BATLOW# 3.3V
                SM_INTRUDER# 2.8V
                PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
                THat is can confirm PCH relate issue...
                05-28-2024, 01:30 AM
              • m.a.sh
                Asus Zenbook pro 14 ux6404vi schematic or Boradviews
                by m.a.sh
                Hi i need help with Asus Zebook pro 14 ux6404vi schematic or Boradviews
                i have ic damage (Bknn 023 ) i need same ic icant find same ic , so i need file Schematic or Boardviews to find ic info .
                09-04-2025, 03:51 AM
              • Fisch46
                ASUS N550JV Schematic
                by Fisch46
                I'm not new to this board but this is my first posting so I hope I'm doing this right. I'm looking for the schematic for a ASUS N550JV motherboard P/N: 60NB0860-MB1B10. I have the board view but need the schematic also. TNX
                07-31-2025, 07:12 PM
              • gurj1979
                Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                by gurj1979
                Hey guys.
                Need help with this one.
                Fan not spinning due to missing PWN Fan signal.
                Also 5 seconds from powering up it freezes, unless in BIOS.
                But as soon as Windows starts to load, it will freeze.
                CPU is COLD / Room temp when it freezes.
                I've replaced the CPU, same problem.
                Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                Replaced fan - same problem.
                Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                08-19-2024, 05:22 PM
              • whatamidoing
                Boardview/schematic for an ASUS E3-PRO V5
                by whatamidoing
                i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
                I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
                I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...
                01-18-2025, 09:17 AM
