Macbook Air 13ich A1466 trackpad 923-0438 and keyboard schematic request
  • Sierra89
    • Feb 2019
    • 3
    • Mordorland
    Hello!
    I've used this forum a lot in the past and always found the information I needed to keep on learning and solving the problems. This time, though, I haven't been able to find what I needed so I wonder if any of you could share it.
    I have a 2017 Macbook air A1466 that won't turn on.
    I can turn in on with the power pads, and even shorting the SMC_ONOFF_L
    line to ground in both sides of the flex cable (mother board and trackpad board), I also changed the whole keyboard assembly to a new one which works well.
    All this leads me to think that my problem is in the circuit embedded in the trackpad. So it would be very useful for me if somebody could share a schematic of the A1466 trackpad (923-0438 if I'm not mistaken) or even for the keyboard, if the power key is routed directly through the keyboard connector to the flex board that goes to the main board I could just run a jumper wire.
    Thanks a lot for your help!
    Edit: I've also checked all Voltages in J4800 connector and all make sense (including SMC_LID at 0V with closed lid and 3.4 with open lid). It's just that a power button press won't drive SMC_ONOFF_L low.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Macbook Air 13ich A1466 trackpad 923-0438 and keyboard schematic request
    No schematics available for touchpad and keyboard. It's almost always a keyboard problem, but sometimes the touchpad and its cable can be the problem as well.
    • Sierra89
      • Feb 2019
      • 3
      • Mordorland
      I'm 99% sure it's not the keyboard and all other keys work in 2 keyboards I've connected to it, and power key fails in both. It's also not the cable from the touchpad to the motherboard because if I manually short the data line responsible for the power button signal to ground (thus activating it as it's active low), the device powers on/off, and this remains true at both sides of the cable.
      It's a shame there are no schematics, it would be such a simple fix if I knew where I can bridge that data line to so that it connects to the power button...
      Thanks for your help and time in any case!
      • audiomodder
        • Dec 2017
        • 54
        Good news my friend, I had this same problem and reverse engineered the protocol completely. I documented how the keyboard interface works and how you can measure and repair / workaround the power key, in exhaustive detail here:
        https://www.youtube.com/watch?v=3QbX2XuuY8w
        All repair docs: ********************
        (also attached here)
        Some summary from Readme:
        1. SMC_ONOFF_L goes low to turn on SMC/CPU
        this comes directly from keyboard with only
        a 1K ohm (R5710) standard resistor for logic and parallel
        capacitor (C5710) for debouncing.
        2. All other keys for SMC RESET (option, left
        shift, control) are active HIGH, connecting
        to PPV342_G3H when pressed. These go through a NAND (u5750 / SLG4AP021) to create SMC_TPAD_RST_L.
        3. When both SMC_ONOFF_L and SMC_TPAD_RST_L are low, SMC is RESET by U5010 (SN0903048)
        Page 53 Macbook 13" for NAND SMC RESET
        Page 53 Macbook 13" for Keyboard conn.
        Page 41 Macbook Air 11" for SMC RESET
        if power key press does not create 1K (R5710) to GND on SMC_ONOFF_L, keyboard is broken.
        **SPECIAL THANKS TO**
        Louis Rossman
        Badcaps.net/forums (yall are my heroes!)
        OpenboardView free software!
        SumatraPDF free software!
        • howardc64
          • Jun 2017
          • 636
          liquid spilled 2013 A1466 with a left shift key stuck pressed. Used audiomodder's inspiration and found a key probe point on the trackpad to determine if fault was trackpad board or kbd. Turns out it was kbd.
          Easiest test would have been a known good trackpad (easy to replace+test). But not available in my case (initially, eventually got hold of one to confirm diagnostic result) and probably not available for most people who don't have a shop or multiple of the same models around.
          As audiomodder showed, left shfit, opt, and ctrl keys are special. They trigger SMC reset at boot. Therefore have dedicated lines rather than a column/row matrix like most keys. On the 2013 A1466, the SMC manual reset isolation logic is integrated into a single 11 pin chip on the trackpad module. This 11 pin integrated chip seems common for this era. A1502 has the chip on logic board. Thus boardview and schematics provide clear diagnostic trace points.
          Attached is a part of the 13 A1466 trackpad. I've labeled this 11pin (1 pin in center hidden from view) chip according to A1502 schematic counterpart. Pin 1 (left shift) is the probe point to see the left shift key voltage both pressed (3.42v) and unpressed (0v pulled down presumably by chip internal resistor) In my case, unpressed shows a range between 1.2 to 2.8v indicating a short to the 3.42v supply in the keyboard. When known good 2nd trackpad became available, this result was confirmed. A couple of pics are attached for reference.
          BTW, googling showed a lot of stuck pressed left shift key problems on Macbooks. Perhaps the reason is it is right next to the 3.42v line on the keyboard flex/connector layout. Corrosion from moisture would cause current to flow from 3.42v line to left shift line signaling its being pressed. Any liquid spill on the keyboard likely trap moisture inside above the black protective plastic. Trackpad also sits above the flat battery offering another source of sitting moisture for corrosion.
          Anyway, thanks to audiomodder (and originally Louis Rossman of course) for the inspiration.
          • migsu
            • Apr 2022
            • 6
            • Philippines
            good day sir, may i know were is the power pad of 2017macbook A1466 ? thank you in advanced
            • Vliegenier04
              Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
              by Vliegenier04
              Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
              I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
              Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
              06-16-2025, 12:03 PM
            • mitchw
              MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
              by mitchw
              Hello
              I got this MacBook Pro M4 Pro to have a look at.
              It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
              Since it was liquid damaged, warranty does not apply anymore.
              Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
              The main issue was that the screen remained black.
              Anyways I cleaned the liquid damaged area, put the machine back...
              09-06-2025, 07:19 AM
            • biosdi
              MacBook Pro A1989 trackpad and keyboard not working
              by biosdi
              Hi guys.
              I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
              thanks...
              04-17-2025, 09:42 AM
            • iMuhtaseb
              A2681 Keyboard, trackpad and sleep?!
              by iMuhtaseb
              Wow it's been a while since I posted!
              This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
              A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
              It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
              Tested another locked logic board on customer's top case and it posted with keyboard and...
              05-22-2025, 09:59 AM
            • oemelectronic
              Macbook M1 820-02016 Keyboard -Trackpad stop working after a while
              by oemelectronic
              Hi friends.
              This model has a very weird fault.
              Macbook Air M1 A2337 - 820-02016
              it works for a while and after a few minutes the TRACKPAD AND KEYBOARD stops working
              I already formatted, I already changed flex and trackpad. The error continues, I tried with another keyboard and the same error happens.
              works for a while and then stops working trackpad and keyboard
              (i rebooted and it works again, after a few minutes the failure returns)
              THE BOARD LOOKS VERY CLEAN and IMPECCABLE
              09-30-2022, 08:37 PM
