dag35dmbad0 rev: d Schematic
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    SY8208CQNC=MT
    RT8813DGQW=4e
    95829 is ISL for vcc
  • DioTheSlayer
    • Oct 2018
    • Russia
    Originally posted by DeniS182
    Thanks.
    and 7J is RT8816AGQW. No voltages on IC's.. only 19V is on mosfet near DC IN connector. I need schematic..Does anyone have it?
    ok maybe too late, but
    MOD EDIT: Posts moved to new thread from this one - https://www.badcaps.net/forum/showthread.php?t=68891
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      Re: HP Omen 15-ax201ns bios dump
      Thanks for your schematic + BV
      • metropolisystem
        • Jan 2016
        • 40
        • Colombia
        I flashed main bios, but notebook is totaly dead as before . No lights, nothing. I don't have any voltages , only 19V rail..
        What are these ic's?
        7J-3L
        Z22610
        MT608
        95829 hrtz
        4e=3k
        hi friend, I had that same problem with that board and it had a damaged mosfet near the processor, but it is not a common mosfet
        • metropolisystem
          • Jan 2016
          • 40
          • Colombia
          the ref of mosfet is E6930, this mosfet is next to two R22 coils near the usb port
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
          • atunguyd
            Acer x163w Monitor PSU schematic
            by atunguyd
            Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
            The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
            03-05-2025, 02:08 PM
          • Thetechdude
            MSI Ventus RTX 4080 16G Broadview schematic needed
            by Thetechdude
            Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
            I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
            Thanks.
            07-15-2025, 11:15 AM
          • ianpoultonknights
            Zenbook Flip 15 UX562AI schematic
            by ianpoultonknights
            Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
            06-26-2025, 02:41 PM
          • Adv10119
            Need help please! schematic for LA-9982P rev 3.0 (A02)
            by Adv10119
            Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
            I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
            I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
            01-31-2024, 01:18 AM
