Please upload Schematic for hcl me xite l 1014 schematic, Part NO:- 15BFC2 01100
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    • 20391
    Re: Please upload Schematic for hcl me xite l 1014 schematic, Part NO:- 15BFC2 01100
    Are there any other part numbers on the board like MB40IA1 REV.01 ?
    https://www.badcaps.net/forum/showthread.php?t=42517
    • k24a1
      (Request) PowerBook G3 PDQ/Wallstreet II 820-1014-A main board schematic
      by k24a1
      Modifying a spare board to populate the unused VRAM slot and I'd like the schematic so I can see if there's anything else I need to do, or if there's a way I can activate it if it's not enabled by default. P/N is 820-1014-A... yes, it's 26 years old I know!
      06-22-2024, 01:33 PM
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
    • G-Sting
      iPad Pro A1876 SHORT Part Identify Help Needed
      by G-Sting
      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
      SO My main concern is what part should i order what should i search the name for ?
      on Ipad...
      05-15-2025, 09:30 AM
    • Yanleb
      Panasonic part number in service manuals
      by Yanleb
      In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
      This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
      For an example, look at the attached PDF.
      Do you have a way to cross reference the Panasonic part number with the actual part number?
      Thanks....
      07-03-2023, 08:16 PM
    • TinkerTron
      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
      by TinkerTron
      Hey everyone,
      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
      Instead, here's what's been bugging me so far:
      The schematic...
      03-06-2025, 02:03 PM
