Samsung np-n128 n130 n140 boardview file
  • wilderness34
    • Mar 2020
    • Turkey
    Hi i need this boardview file please.
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • GeckoGreen
    Samsung service bulletin: need firmware file for PN63C550 TV
    by GeckoGreen
    I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
    You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
    The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
    Will you please help me get the [2D63]LOGIC.bin file for my TV?
    05-17-2025, 02:47 PM
  • wasyl
    Acer Nitro AN515-46 HH51R LA-M002P R1A BoardView File + schematic
    by wasyl
    Hi, did not found here so uploading to help...
    09-15-2025, 07:40 AM
  • Vice01234
    Samsung NP270E5E BA41-02243A HST Boardview
    by Vice01234
    Hello, im triyng to search an Boardview of my Samsung NP270E5E. This haves an NVIDIA gpu (GeForce 710M) and i3-3120M. The PCH gets hotter after try to start, he takes 10 seconds to send the IO pulse to start the motherboard. I see all the voltages (5v, 3.3v, 1.5v, 1.1v others) and dont POST after start the motherboard and the CPU dont gets hotter. I used my laptop 11 days followed whiout shut down, the GPU uses an OC (776Mhz to 961Mhz and memory 900Mhz to 1298Mhz). My model of motherboard are BA41-02243A HST (are Lampard-INT 1.0, not amd). I cant found an BoardView in the forum. Someone can help...
    09-17-2025, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
