Dablydmb8e0 rev: E
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    Dablydmb8e0 rev: E
    Hi, i need schematic please for this:
    Dablydmb8e0 rev: E
    i have a power issue
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • claws77
    lenovo flex 5 14itl05 power sequence issue
    by claws77
    hi guys, my motherboard will not start no matter what
    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
    but rest nothing happens no sign of life.
    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
    i have no knowledge of motherboards ....
    10-20-2024, 02:48 PM
  • yaya3gmax
    Laptop Power Issue – Works on Battery, Fails on Adapter Load
    by yaya3gmax
    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
    Symptoms:
    • Laptop works normally on a pre-charged battery.
    • Battery does not charge when adapter is connected.
    • Without battery:
      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
      • Speakers “pop” when power cut occurs indicating harsh sutdown.
      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
    08-21-2025, 07:16 AM
  • Soulzink
    Samsug washing machine. Power supply DC41-00189a board issue
    by Soulzink
    I am trying to fix a samsung washinmachine power supply main board.
    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
    The power supply board reference is the following: DC41-00189a
    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
    04-19-2025, 06:26 AM
  • bcstedt
    LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
    by bcstedt
    LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
    Problem:
    On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
    It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
    01-18-2024, 01:03 PM
