EPK50 LA-G07DP schematics
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need schematics for this model BOARD ID: EPK50 LA-G07DP REV 1.0 please
    • 21933
    Re: hp 15-a0007nx schematics
    No schematic available.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      too bad there is no schematic for this model available i have attached the ic that is shorted
        • 21933
        Start a new thread in the main laptop forum, with clearer pictures and any part numbers you can get from the IC.
        • zameer
          • Jun 2019
          • 22
          • india
          check this
          • Albertoq
            • Jul 2019
            • 11
            • Perú
            Thank you zameer
            • hackersworldprime
              kavinharryjo
              • Nov 2021
              • indian
              Same problem, when i press the power button, PU301 ic has over heat then voltage drop on IO ic pin no 33, and also no voltage send to BIOS pin 3.40v,
              <kavinharryjo>
              how do find out this ic has short? //kavinharryjo//
              equalant ic is AWVBJR and search this SY8286BRAC_QFN20_3X3 . search listed items are working properly //kavinharryjo
              • hackersworldprime
                kavinharryjo
                • Nov 2021
                • indian
                Re: hp 15-a0007nx LA-G07DP schematics
                AND Also working this ic AWW81B. Thats used for when we press the power button Its send 4.5 voltage to BIOS ic
                • Noreddin
                  • Jan 2020
                  • 73
                  • mostaganem
                  Thank you
                  • imroz
                    • Nov 2021
                    • 5
                    • india
                    thank you zameer
                    • gensan
                      • Nov 2015
                      • 3
                      • Ukraine
                      Originally posted by zameer
                      check this
                      Thank you
                      • elbostan
                        EL.BOSTAN TEAM
                        • Apr 2012
                        • 30
                        • egypt
                        thanks
                        • Buchu
                          • Jul 2008
                          • 3
                          I have one of these motherboards that has the same problem with PU301. The chip doesn't seem to be shorted however I have no 3.3V output from it resulting in no 3.3V at the super IO chip or the power button. Has anyone had success replacing PU301 and getting the board working?
                          If I apply 3.3V directly to jumper PJ303, the board will come on so I know there isn't a bad capacitor or something dragging the 3.3V output down.
                          • fichamba
                            • Dec 2011
                            • 135
                            • Spain
                            Thanks a lot, zameer, and happy new year!.
                            • arevut
                              • Mar 2019
                              • 17
                              • Ukraine
                              Re: HP 250 G7 EPW50 LA-G07FP Schematic
                              Here I found for EPK50 LA-G07DP REV 1.0 BoardView
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Is it so hard to attach the file in your post, instead of linking to external site?
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • Tetteh Bismark
                                  • Oct 2023
                                  • Ghana
                                  Re: EPK50 LA-G07DP schematics
                                  Please I need the schematic for EPK50 LA-G07DP
                                    • 21933
                                    You might find the elusive schematic if you read the whole thread
