Chasing schematics & boardview HP laptop model 14s-dq3029TU, board model DAOPAKMB6FO
  • WildTechRepairs
    WildTechRepairs
    • Nov 2022
    • 10
    Gidday from Downunder,
    Chasing the Schematics and also the board view for the HP Laptop board, model according to the board markings that is read sideways against the the side frame to the graphics card or the DDR4 slot it says the following for the Model,
    “MODEL:OPAK”
    Then assuming the card was still inserted into the slot, releasing the card and removing it will reveal the full markings printed on the board (not the card),
    “DAOPAKMB6FO REV:F”
    Below in smaller print is a small logo of I think a backwards R with the letter U with the left stroke of the U and the Back part of the R joined as 1 (will send attached picture to make sense of what I mean,
    After the logo is printed,
    “SH10 94v-0”
    Under that then says,
    E248779
    Then under that says,
    222 1..
    VGT - VGT
    On the underside of the board will be printed with the same
    “DAOPAKMB6FO REV : F” marking.
    Hope this post is well worded and easy to understand and anything I have missed or could do better please let me know as this is my first thread in this forum for BadCaps.net so I am fresh off the boat (fresh ON the boat in this case lol)
    Thanks in advance for any help with this request.
    Any direction you suggest to follow up with will also be of great help and will be able to check out in advance on other projects as well so I am green in the field though believe myself quite capable with making the repairs and just need to get my hands on the right schematics and layout and use the correct information for the job at hand
    I enjoy the learning as you go approach to things so let me have at it if you will,
    Cheers
    Nathan
  • edugimeno
    Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
    by edugimeno
    Hi!!
    Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
    I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
    At a certain point, moving stuff around, I put all wires back in place and...
    03-24-2024, 02:31 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • sotodefonk
    Help finding the correct model of a T-Con board on my Hitachi TV
    by sotodefonk
    Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
    I opened the tv to access the board and took the shared pictures of the T-Con board.
    I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
    I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
    Inspecting...
    06-28-2024, 04:39 PM
  • ksysa
    Board Layout of iPad Pro 10.5 (Model : A1709)
    by ksysa
    Good day, everyone! Can anyone please share a board layout (complete with components, test points, etc.) of iPad Pro 10.5 (Model : A1709)? There is already a schematic diagram of iPad Pro 10.5 here but somehow it lacks the complete board layout. I need to know where the specific Test Points (TP) are on the motherboard. I hope someone can help me.
    07-16-2025, 02:36 AM
