qal70 la-7741p
  • ElJap0
    • Feb 2019
    • 10
    qal70 la-7741p
    Can anyone help me out with the schematic/boardview for this? I have a laptop that will not POST (POST card shows nothing). I was thinking of reflowing the GPU & CPU, but I'd rather try and check out the power rails. Also open to suggestions or any sort of help. Thanks. all of you rock!
  • peste
    • 13597
    • ROMANIA
    Re: qal70 la-7741p
    I hope to help
    • sanshah_08
      • 20
      • india
      Re: qal70 la-7741p
      la-7741p boardview required.
      • kingkong computers
        • Sep 2018
        • 210
        • pakistan
        Re: qal70 la-7741p
        boardview is hare
        • AL._.EX
          • Dec 2022
          • 896
          • Belarus
          Re: qal70 la-7741p
          Boardview
          • mundoinnova
            • Sep 2022
            • 10
            • colombia
            Re: qal70 la-7741p
            thank you so much
            • Doniciputat
              • Aug 2022
              • 111
              • Indonesia
              Re: qal70 la-7741p
              Originally posted by al._.ex
              boardview
              thanks
              • gsmtronic
                • Dec 2023
                • 5
                • dz
                Originally posted by AL._.EX
                Re: qal70 la-7741p
                Boardview
                thank you
                • skwarszczow
                  Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                  by skwarszczow
                  This is my first post on the forum
                  I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                  Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                  Before completing the purchase, we decided to erase...
                  03-23-2025, 06:04 PM
                • SarcasticOP
                  General question about MacBook power rails for repair.
                  by SarcasticOP
                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                  • PPBUS_G3H (12.6V-12.8V)
                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                  • PP3V42_G3H (3.42V)
                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                  • PPVRTC_G3H (3.3V)
                    • This
                  12-12-2024, 05:50 PM
                • Cemal Odabasioglu
                  MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                  by Cemal Odabasioglu
                  I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                  Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                  Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                  Observations...
                  01-14-2025, 03:54 PM
                • ferah831208
                  help with AMD Ryzen 5 7535hs power rails
                  by ferah831208
                  Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.
                  03-09-2025, 01:59 AM
                • DrewPhillips
                  SFX PSU - Need High Current on 3.3V & 5V Rails?
                  by DrewPhillips
                  I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                  The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                  02-18-2025, 01:03 PM
