Dj1 capella uma mb 10212-1 48.4ek19.011 schematic
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Please i needed a schamtic for this model
  • acata
    • Jun 2021
    • 53
    • Indonesia
    Re: Dj1 capella uma mb 10212-1 48.4ek19.011 schematic
    I'm looking Dj1 capella uma mb 10212-1 48.4ek19.011 for PCB layout PDF or a BOARDVIEW file
      • 21922
      https://drive.google.com/file/d/17Lu...uaYzIq_Sg/view
      • acata
        • Jun 2021
        • 53
        • Indonesia
        I'm sorry for late reply..
        Thank you..
        • yihuilin
          HP DV7T-7000 Schematic and Boardview file needed
          by yihuilin
          Hello Geniuses
          I am fix an old Laptop, HP Dv7t-7000, Power Button can't trigger due to water damage, however Re-connect power is able to auto power on
          i need schematic to figure out
          thanks
          10-03-2025, 11:01 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • Dr Techno
          Motherboard Schematic and BoardView file for a AORUS 15P XC please
          by Dr Techno
          Hi Guys,
          I need a motherboard schematic for file for a AORUS 15P XC please. The EXACT motherboard is ga-rx5lxc rev2.0. It currently has a black screen issue and doesn't display to external display but boots into windows and can also display externally when running ubuntu. If anyone has a motherboard schematic file and boardview for this laptop it would be greatly appreciated. Thanks in advance!​
          05-01-2025, 01:45 PM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Thetechdude
          MSI Ventus RTX 4080 16G Broadview schematic needed
          by Thetechdude
          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
          Thanks.
          07-15-2025, 11:15 AM
