La-8861p
  • Techtiger
    • Oct 2014
    • 1601
    • france
    La-8861p
    guys need help why is not possible to find any components this Schematic (i ma using adobe) Adobe search/Find bar , it say protected I try to unlock onlie not working if some one can help
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: La-8861p
    Try open it with PDF-XChange Viewer, You can't type on search/find bar, only with Select Tool, Copy and paste on search /find bar.
    • Techtiger
      • Oct 2014
      • 1601
      • france
      Re: La-8861p
      Thanks on/off
      • Verlengsnoer
        Unlock password protected SSDs
        by Verlengsnoer
        hi, i have a bunch of ssds, and those are password protected and unusable,
        are there ways to unlock them?
        i dont know what data is on it, and its fine to reformat them.
        hope someone has ideas to unlock the ssds
        01-14-2022, 08:18 AM
        by Vesko356
        08-11-2023, 03:27 AM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • remizbushka
        Dell inspirion 5775 bios "Unlock Setup fail"
        by remizbushka
        Hi sirs. please help
        Dell Inspiron 5775 bios locked "Unlock Setup fail"
        After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
        What I did:
        I read the bios dump.
        Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
        03-24-2025, 09:07 AM
      • corrize
        Where to find a very small fpc connector 0.3mm between 2 pins ?
        by corrize
        Hello, I search this connector (oxydated).
        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
        Do you know how to find this connector please ? What is the exact name for find it ?
        08-06-2024, 05:25 PM
