Msi gp62 6qf schematic
    Msi ge62 6qf
    ms-16j51 ver : 1.0
    Re: Msi gp62 6qf schematic
    Originally posted by medinfo View Post
    Msi ge62 6qf
    ms-16j51 ver : 1.0
    here
      Thanks.
        I thank you as well.
          Thank you
            Thank you very much
              Thanks a bunch.
                Thank you!
                while alive { live(toFullest=true) }
                  is this the schematics for all versions of the ge62 6qf? In other words is this the one i need once i have the ge62 6qf?? thanks in advance.
                    Thank you very much, I've been looking for a long time, thank you again
                      Thanks mate
                        thanks!
                          Thanks also..
                          And sharing a personal MultiMeter trick to help others..
                          File/Sand down your MultiMeter probes (ends/tips) to a very small and fine needle tip [not only useful but critically necessary] when testing SMD [surface mount] components like on Laptop Motherboards.
                          I myself just use my Harbor Freight version of a Dremel with a flat griding/sanding disc, and then hold the multimeter probe almost flat on the sanding disc while turning [with your fingers] the meter probe in a circular mother to evenly sand the probe tip..
                          Hope this helps others and never having seen anyone mention this tactic, I'm suggesting it to others. For myself, decades ago, this was my Instant, Cheap and easy solution to the DMM probe tips being too large..
                          though I have another trick, similarly related which is useful for other purposes..
                          Take a PAPERCLIP, unbend it and straighten it out, then bend it around, over and over, the metal end of the DMM probe then using needle nose pliers, when you have about 1/2 to 3/4 of an inch remaining, you can bend the paper clip at a 90 degree angle, close to the metal dmm probe, so that effectively 'extending' the metal probe.
                          So the end result is not only 'thinner' DMM Probe Tip(s) but a LONGER probe tip length to reach into deeper areas.
                          And don't forget to slide a piece or two of HeatShrink tubing over the 'new' metal paperclip probe tip, right up to the end [aka pointy tip] of the probe to insulate and protect against shorting things accidently when using the new probe..
                            thank you
                              Originally posted by Pragmatiko View Post
                              here
                              tanks
                                Thanks.
                                  here
                                  thanks for you share bro. help full
