ASUS X200CA board power issues (schematic and datasheet attached)
  • gigabyte898
    • Sep 2016
    • 6
    Hey,
    I've gotten fairly far into this diagnostic but I thought I'd get some input (no pun intended). We had an ASUS X200CA brought in not powering or showing any signs of life. No luck with power flush so I tore it apart to get the board. Found the motherboard schematic (ASUS doesn't like numbering their boards with anything besides the laptop model but they also seem to re-use boards in different models) and essentially just followed power all the way from the 19v DC jack to a step-down switch mode power supply IC chip.
    Datasheet for the chip says it takes the input and switches it to a 3v and 5v output with PWM buck converters as well as handles onboard power-up sequencing, a power good output, internal soft-start, and a soft discharge output that prevents negative voltage during shutdown. Made sense this would most likely be the issue so I tracked down where it was on the board and it was a little gunky around the area.
    Took the chip off, cleaned both it and the board with rubbing alcohol, put it back on, and viola it powered up. My excitement was short lived though as it powered down 30 seconds later. The same thing happens each time I turn it on. Shows the red charging LED, it powers up when I press the power button, and then clicks off entirely shortly after.
    My initial thought is to just replace this IC chip, but part of me is second guessing that's the only issue. Any of y'all ever experienced this before? Any thoughts on if something else could be contributing or should I just go ahead and order the chip and see if it works when it comes in. I've attached the board schematic I'm using as well as the datasheet for the IC in question, Page 79 on the schematic is where the chip is mentioned with the ID PU8701A
    Thanks,
    Brandon
    Last edited by gigabyte898; 01-30-2018, 11:04 AM. Reason: Added clarification of where the chip is on the schematic
  • khaahk
    • Dec 2013
    • 813
    • Estonia
    Re: ASUS X200CA board power issues (schematic and datasheet attached)
    And during that 30s time, does this ic provide 3.3V and 5V. If it does then most likely the problem is elsewhere. Onboard ram is common point of failure if it is X200CA. The schematic attached is not related to the topic. Which board it is?
    The K40AB most likely problem related to AMD northbridge or video chip.
    • gigabyte898
      • Sep 2016
      • 6
      Thanks for the reply, it does supply the correct voltage before shutting down. Grabbed that schematic from a different site but the guy posting it claimed it was close enough to the X200CA to ID what components are. One thing I did notice after posting this was the area with the IC was hotter than the rest of the board by a lot. I'm sure an IC that downsteps 19v to 3.3v is going to get toasty but it was enough to raise eyebrows. The client this is for ended up just telling us a few minutes ago not to bother with board labor and just replace the entire thing so it doesn't matter too much anymore, but I'll keep in mind what you said about the RAM and IC if this model crosses my path in the future
      • BlueMidnight
        • Jan 2015
        • 489
        Just for future reference... The 3V/5V chips create 4 main voltage rails:
        - A low power 3V linear/LDO output
        - A low power 5V linear/LDO output
        - A high power 3V switching/buck output
        - A high power 5V switching/buck output
        The linear regulators are built into the chip but the switching outputs are generated by controlling 2 pairs of external MOSFETs.
        These 3V/5V chips should never ever be hot. If you have to wonder if it's too hot, it's too hot. An overheating 3V/5V chip is caused either by a bad chip or by a short on either the 3V or 5V linear outputs (or both).
        In the future, you may diagnose this condition by using a multimeter set to diode mode. With the board unpowered, place the red lead on ground, and place the black lead on each of the 4 outputs of the 3V/5V chip (best to check all of them). Anything near 0V on the output means there is a short to ground on that rail.
        Likewise, if the source of the heat isn't the 3V/5V chip itself, but something nearby, then you would check for shorts in that area. Really nothing should get exceptionally warm on a motherboard except the areas with high amperage, like the CPU, GPU and voltage regulation section supplying those.
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • DynaxSC
          ASUS STRIX Z490-F GAMING - No POST, stubborn board
          by DynaxSC
          I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
          The situation looks like this:
          After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
          1. RTC oscillates normally (32.768KHz).
          07-08-2022, 05:45 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ShadowAi12
          ASUS ROG STRIX B550-F GAMING — Board not powering on properly
          by ShadowAi12
          I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
          • The board enters a "ready to power on" state after plugging in the PSU.
          • Pressing the power button increases power draw.
          • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
          Measurements:
          (taken after pressing the power button, while the board is attempting to start)
          • H_SKTOOC#
          06-11-2025, 01:05 PM
        • jimbodriver
          Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
          by jimbodriver
          I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
          Initial results:
          Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
          03-20-2022, 02:30 PM
