Hp.15 AHL50/ABL52 LA-C701P REV 1.0 schematic
  • vikaspowar
    • Jul 2016
    • 5
    • india
    #41
    Re: Hp.15 AHL50/ABL52 LA-C701P REV 1.0 schematic
    Sir ...pls provide
    la-c701p uma converstion and board view.
    Thanx
    • whitevolf
      • Feb 2014
      • 123
      • TÜRKİYE
      #42
      thank you
      • sebkarimpour@gmail.com
        Valiasr
        • Aug 2019
        • 25
        • Iran
        #43
        • victor_quiroga
          • 62
          • argentina
          #44
          thanks
          • vik1100
            • Sep 2021
            • 6
            • europa
            #45
            • Repdata
              • May 2020
              • 67
              • Deutschland
              #46
              schematic
                • 21465
                Originally posted by Repdata
                please
                Please/bitte do not post bios dumps in the schematic requests section.Likewise,do not post schematics in the bios requests section.
                • vaults
                  • Sep 2021
                  • 5
                  • philippines
                  #48
                  Thank you so much
                  • Stantechs
                    • May 2011
                    • 28
                    • Nigeria
                    #49
                    I am happy to belong to this forum
                    • supercomputer
                      • Mar 2022
                      • India
                      #50
                      Need board view hp 250 g4
                      • swastik201
                        • Aug 2019
                        • 6
                        • india
                        #51
                        thanks a lot bandhu
                        • mberbouch
                          • May 2014
                          • 108
                          • Morocco
                          #52
                          Originally posted by yashan
                          form **********.com
                          Thank you so much for sharing this schematics.
                          • dqtech
                            Badcaps
                            • Jul 2018
                            • 632
                            • N/A
                            #53
                            thanks
                            • 10r
                              • Aug 2023
                              • 3
                              • india
                              #54
                              Can anyone please share hp ahl50/abl52 la-c701p rev 1.0 boardview
                              • Zilicon
                                AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
                                by Zilicon
                                Hearty greetings to everyone, trust you all are doing excellently well.
                                Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
                                The power stables in very rare case. Once it was stabled, everything works fine.
                                Once the power switched is pressed, 5V and 3V were present.
                                The things i have done:
                                1. I have check for shorts on the board, but nothing. The board is short free
                                2. Not a power switch problem, it behaves the same without the switch ...
                                06-10-2024, 05:05 AM
                              • TinkerTron
                                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                by TinkerTron
                                Hey everyone,
                                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                Instead, here's what's been bugging me so far:
                                The schematic...
                                03-06-2025, 02:03 PM
                              • atunguyd
                                Acer x163w Monitor PSU schematic
                                by atunguyd
                                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                03-05-2025, 02:08 PM
                              • Thetechdude
                                MSI Ventus RTX 4080 16G Broadview schematic needed
                                by Thetechdude
                                Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                Thanks.
                                07-15-2025, 11:15 AM
                              • ianpoultonknights
                                Zenbook Flip 15 UX562AI schematic
                                by ianpoultonknights
                                Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                06-26-2025, 02:41 PM
