Re: Hp.15 AHL50/ABL52 LA-C701P REV 1.0 schematic
I need HP 250 g4 LA-C701P board view please
https://drive.google.com/file/d/10rL...cO1UneR2u/viewLeave a comment:
Attached FilesLeave a comment:
Hp.15 AHL50/ABL52 LA-C701P REV 1.0 schematicAttached FilesLeave a comment:
Attached FilesLast edited by SMDFlea; 07-15-2019, 03:23 AM.Leave a comment:
Hey Guys, Most awaiting Schematic is now Available. Enjoy. Just Help eachother, Don't ask money to help.Attached FilesLeave a comment:
An update to the subject. LA-C701P schematic is now available for purchase in many paid sites. It is against forum rules to post links to premium sites so i cant post direct links here. Those who need it simply Google, get the link and buy, if they choose.Leave a comment:
hp.15 AHL50/ABL52 LA-C701P REV 1.0 schematic PLEASELeave a comment:
la-c701p rev 1.0 schematic i needLeave a comment:
jarmans how is your mother board now work or not?Leave a comment:
c701p not on,but dc jack light is ok.and power button voltage is ok.io programe ok.but not onLeave a comment:
Mx 25l6473eLeave a comment:
by ZiliconHearty greetings to everyone, trust you all are doing excellently well.
Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
The power stables in very rare case. Once it was stabled, everything works fine.
Once the power switched is pressed, 5V and 3V were present.
The things i have done:
1. I have check for shorts on the board, but nothing. The board is short free
2. Not a power switch problem, it behaves the same without the switch ...06-10-2024, 05:05 AM -
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by atunguydIi wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...-
Channel: Schematics and Boardviews
by ThetechdudeHi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
Thanks.-
Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
Channel: Schematic Requests ONLY!
06-26-2025, 02:41 PM -
- Loading...
