Asus S301 Schematic or boardview
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    #41
    Re: Asus S301 Schematic or boardview
    Originally posted by JaroTech
    If you want to confirm a short on the 19V power line, you must remove the resistor 10mOhm, but you did not give me the picture I asked for. So I don't know where is this resistor.
    Sorry, but must have missed this request !
    Even Now i don't see the post where you ask this?
    Can you point where is the area of the mobo you need the picture ?
    • JaroTech
      • Mar 2015
      • 351
      It's the post #9 on the first page.
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        #43
        I did answer on Post 11, anyway here a better picture with all the area you asked.
        • JaroTech
          • Mar 2015
          • 351
          Sorry, but I can't find the resistor from the pictures you already post. You should start with changing this chip (BQ735), if you still don't have 19V on the motherboard, we need more troubleshooting to find the defective component. (But I was right about the screen)
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            #45
            Ok, since only 3 of us have participated to this thread, if the solution is the above, i will give 20 bucks to each.
            Just a little sacarsm.
            Will kreep updated once i receive the new BQ.
            PS: i will order only after the holidays
            • JaroTech
              • Mar 2015
              • 351
              @passete, I don't do this for the money, give the money for a good cause. I'm an Electronics Technician, I know what I talking about for your problem. But i don't have the schematics for your laptop, so, i extrapolate the troubleshouting from what I have.
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                #47
                Here again the barrier of language !
                You misunderstood me Cousin , I appreciate all your time and wisdom .
                Was hoping for others to ... ohh well,... hope you understand
                PS: Will try to find this IC on my Mobos collection, otherwise I will order it.
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  #48
                  Will a BQ25A work in replacement of a BQ735 ?
                  Or is there a compatible IC ?
                  • nevermind1993
                    • Aug 2016
                    • France
                    #49
                    Hello, I have the same problem.
                    How did you solve it?
                    Thank's
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      #50
                      Received today the bq735, i don't see any change, still no voltage on bios ic, power switch etc ...
                      @JaroTech buddy, what is the next step ?
                      • meritosari
                        • Oct 2010
                        • 774
                        • Indonesia
                        #51
                        10 milliOhm resistor was located near sw5901 visible smd part with R010 on it
                        • passete
                          Living=Sharing
                          • Jun 2015
                          • 487
                          • France
                          #52
                          Hey buddy, thanks for your reply.
                          I don't understand what you mean, you want me to remove this resistor ?
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            #53
                            I just want to make sure that you have no short circuit as jarotech said at post#40 (cont'd post#40)
                            what about resistance on this resistor respect to gnd? low or high
                            • passete
                              Living=Sharing
                              • Jun 2015
                              • 487
                              • France
                              #54
                              I don't have any continuity on the 3 Points that i've measured, but i get a low voltage, 0,98V.
                              This is strange, if i use the metal cases of the usb/hdmi as ground, i get no continuity, but i found a point on the mobo that i can measure 0,03 Ohms on the 3 points
                              • meritosari
                                • Oct 2010
                                • 774
                                • Indonesia
                                #55
                                So, you've found short circuit at 19v rail.
                                use asus ux31a2 scheme as reference, on 3 points what you've measure it was P_CHG_PATH_19V_SHAPE
                                • nevermind1993
                                  • Aug 2016
                                  • France
                                  #56
                                  HI, i have the same problem and i changed the two fet neaarly the power boton (as show on the joined picture), and the pc turn on an reborn.
                                  Thank to all for your help
                                  Eric
                                  • passete
                                    Living=Sharing
                                    • Jun 2015
                                    • 487
                                    • France
                                    #57
                                    Eric
                                    Are you 1OO% sure that your problem was the same ?
                                    Before changing the fets, what were the voltages on those 2 ?
                                    • passete
                                      Living=Sharing
                                      • Jun 2015
                                      • 487
                                      • France
                                      #58
                                      SOLVED, SOLVED, SOLVED, ....
                                      Lol, it was just this 2 Fu""""" Fet's near the input Socket !
                                      Un Grand merci a toi nevermind1993
                                      Also a very Big Thanks to Meritosari for your patience Buddy, if one day you visit France, i will pay a Dinner
                                      To Finish, also a big thanks to the 2 Other members that Helped, you guys are Great.
                                      • meritosari
                                        • Oct 2010
                                        • 774
                                        • Indonesia
                                        #59
                                        You're welcome
                                        • Brilliant
                                          • Oct 2016
                                          • 5
                                          • Italia
                                          #60
                                          Hi all, can anyone tell me the name of those fet , i cant find them on ebay or similar for buy them.
                                          • newmemberguys
                                            Request: Schematic and Boardview for ASUS Zenbook S16 (UM5606WA) – 60NB13M0-MB5200
                                            by newmemberguys
                                            I'm looking for the schematic and boardview files for an ASUS Zenbook S16, model UM5606WA (2024).
                                            The reason I’m asking is that I recently caused some physical damage while trying to clip the BIOS chip with a CH341A programmer and SOIC8 clip. Specifically, I knocked off some components (possibly 6, though I’m not 100% certain as I don’t have much experience with this) around the bios chip as you can see in the photos attached. I was able to recover 3 of them which are now taped on the battery.
                                            To help with identification, here is the full...
                                            07-13-2025, 10:27 AM
                                          • whatamidoing
                                            Boardview/schematic for an ASUS E3-PRO V5
                                            by whatamidoing
                                            i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
                                            I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
                                            I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...
                                            01-18-2025, 09:17 AM
                                          • adamski1952
                                            Asus prime B560M-A rev 1 schematic/boardview
                                            by adamski1952
                                            Hi all.
                                            Looking for asus prime b560m-a r1.02 boardview and schematic please.
                                            06-14-2025, 10:58 AM
                                          • Pier
                                            ASUS MAXIMUS VIII IMPACT Boardview, Schematic & Repair Guide
                                            by Pier
                                            As the title states i am looking for a schematic and boardview for the ASUS MAXIMUS VIII IMPACT motherboard.
                                            I know that the boardview exists (ASUS MAXIMUS VIII IMPACT REV1.01.fz) but cannot find it free of charge, the schematic however might not be leaked.
                                            For anyone interested, the repair guide is attached to this post.
                                            Thanks....
                                            09-23-2023, 07:21 AM
                                          • xtint16
                                            Asus Zephyrus G14 (2024) GA403U Schematic or boardview.
                                            by xtint16
                                            Asus Zephyrus G14 GA403U was one of the most popular laptops of 2024.
                                            It would be very helpful to have schematic or boardview for this laptop.
                                            05-07-2025, 06:33 AM
