asus X551 and asus X553 schematic
  • dj_ricoh
    • 2073
    • uk
    hello tech guys!
    anyone got a schematic for those models?
    thanks
    one liquid dmg(x551) and 553 manual short.
    some bloke try to take the battery out and made a short by braking the shield from battery connector.
    after the short no power and there is a buzz in the board.
  • hansie55
    • Dec 2013
    • 254
    • Netherlands
    Re: asus X551 and asus X553 schematic
    Sorry mate, I tried and can't get them. Not even if I paid for them
    • naeemshahzad
      • Jan 2015
      • 129
      • uae
      did you get the schematic ?
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Hope is good
        • naeemshahzad
          • Jan 2015
          • 129
          • uae
          it is just a Guide .
          • erhanabdullah
            • Nov 2015
            • 24
            • turkey
            if you see a liquid contact on boards ,use window cleaner or liquid soap and scrub than blow by air gun.
            • OOF DIO
              ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
              by OOF DIO
              (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
              (Had 3 problems, now just 1)
              I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
              I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
              I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
              04-19-2025, 05:03 PM
            • jkucukov
              Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
              by jkucukov
              I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
              During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
              02-05-2025, 09:27 PM
            • Guest
              Request: Schematic and Boardview for ASUS Zenbook S16 (UM5606WA) – 60NB13M0-MB5200
              by Guest
              I'm looking for the schematic and boardview files for an ASUS Zenbook S16, model UM5606WA (2024).
              The reason I’m asking is that I recently caused some physical damage while trying to clip the BIOS chip with a CH341A programmer and SOIC8 clip. Specifically, I knocked off some components (possibly 6, though I’m not 100% certain as I don’t have much experience with this) around the bios chip as you can see in the photos attached. I was able to recover 3 of them which are now taped on the battery.
              To help with identification, here is the full...
              07-13-2025, 10:27 AM
            • whatamidoing
              Boardview/schematic for an ASUS E3-PRO V5
              by whatamidoing
              i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
              I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
              I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...
              01-18-2025, 09:17 AM
            • mysnoopy
              Asus FX516PC R6.0 schematic
              by mysnoopy
              Hello
              I need schematic for this model ASUS FX516PC R6.0
              Thanks.
              12-27-2024, 03:41 PM
