Toshiba Satellite C850-B720 no power - schematic
    hi,
    does anyone have schematic of this mobo?
    PLF/CSF 45W UMA & DSC MB
    REV 2.1
    TIA
    Re: Toshiba Satellite C850-B720 no power
    shematic
    https://www.badcaps.net/forum/showthread.php?t=35111
      aanan,
      thanks for the link.
      Laptop now works.
      Found 2nd FET shorted. replaced and laptop turns on using DC bench supply.
      when i used the charger laptop quickly died. ???$$##??
      i noticed charger was repaired recently and i suspected something wrong with it so i checked the output and found out that it was reversed polarity...
      replaced the FET again and corrected the polarity of the charger made the laptop and charger works normally.
        Hey fddizon, yesterday i got the same laptop with a very same problem, like you had. I suspect it has suffered from charger with reversed polarity as well, but unfortunately i'm not so techy with finding these fets, as i'm still learning to solve problems on such a low level. Was it this one? (just a guess)
        https://cdn.badcaps-static.com/pdfs/...c46783c0ed.pdf
        If not, could you give me a part number, or a marking on the circuit board, which mosfet was shorted? Thanks!
          Same problem with a C855, I will try to replace the mofset.
          How did you reverse the polarity of the charger ? Did you just reverse cables ?
            yes,
            thats what i did. reverse the cables from the pcb.
              yaman,
              yeah it looks like that. so tiny that i cannot read the part number.
                Mofset switched but still no power, 19v in 1v out.
                1 V also for the battery, I don't think it's charging with this voltage.
                  Originally posted by fddizon View Post
                  hi,
                  REV 2.1
                  TIA
                  I'm searching for bios and ec for this mobo PLF/CSF 45W UMA & DSC MB, i have no power/lights.
                  Strange thing, is that some components get warm, like coils, pch once i connect the PSU.
