hey guys ,need HP Envy 14 schematic
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    Re: hey guys ,need HP Envy 14 schematic
    techman like i mention
    computer turn on and gives image perfect !
    The only problem is ,, if its to long without AC adapter on ,.,, it will not turn on on the moment , only after beeing with AC adapter on for smoe good minutes it will let the computer turn on .(for ex 10:45 inserted ac adapter and tryed to turn on , it didnt turn on , then 7 minutes later i tryed to turn on , and it turn on , ad from now on it alwas turn on
    thats the only problem !
    Im with a HALFMANN 120w adapter , more than enough for this . i dont have the original charger
    model envy14 1040ep
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      ok my bad , not cheking carefully entire schemtic i found were the LED socket for the dc jack is .. CN1100 , let me carry on some test
      also got the battery now
      • highpulse
        i hate HP
        • May 2013
        • 1489
        • portugal
        well when i insert the battery the LEd of the dc jack start flashing less than one second or pratically a second per flash . let me chek on hp site what happen when its charging
        • highpulse
          i hate HP
          • May 2013
          • 1489
          • portugal
          the dc jacmk light only turned orange after i turned the computer on ... or else it would stay blinking forever .. now i shuted the pc of and still with the orange led on the dc jack (like charging ) seems a bad charger board , what are your opinions about"?
          • highpulse
            i hate HP
            • May 2013
            • 1489
            • portugal
            techman , so what abou that bios ?
            • techman1025
              • Jun 2014
              • 497
              Hi if this don't work send me full model number and original bios back up and i will make sure you get a working sent .
              techman1025
              • highpulse
                i hate HP
                • May 2013
                • 1489
                • portugal
                #27
                thk mate , i will now test again the board and then will put the bios to test it
                • highpulse
                  i hate HP
                  • May 2013
                  • 1489
                  • portugal
                  #28
                  12:01 inserted dc source led dont light up , 30 seconds after is started to light up and charging battery ! this before making flash on bios
                  • techman1025
                    • Jun 2014
                    • 497
                    Here
                    is the EC.BIN
                    TECHMAN1025
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1489
                      • portugal
                      #30
                      this 2 one to reflash ? ok , your first altough works too , let me try this one
                      • techman1025
                        • Jun 2014
                        • 497
                        Hi
                        The sec file i use from the board number...because you never gave me the full model number thats inportant because the board number it fully help a lot more work to find the correct update.
                        techman1025
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1489
                          • portugal
                          #32
                          i gave you full number
                          chek the previous posts
                          i will reinsert here
                          hp model envy14 1040ep
                          board info
                          model board -> 6050A2316601-MB_A03 ( this is the only code on the motherboard)
                          DYnamic KM-VO
                          HSTNN-180C Discrete
                          info on components
                          KBC IT8502E (NXA)
                          ECbios MX25L4005A
                          MAINbios MXL253205D
                          • techman1025
                            • Jun 2014
                            • 497
                            Hi
                            the sec file is the correct one ....so whats the out come?
                            techman1025
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1489
                              • portugal
                              #34
                              well , worked nice , weird issue , because even after that bios update , it was still haging a bit before having LEd turned on . but saturday board started to work ok , when i insert dc jack the light would turn on in the 2 sec after like its usual .. weird issue .. im a bit afraid of this repair .. not trusting much on this .. later on when i arrive at home i will try it again before deliver it to my client .
                              cheers
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1489
                                • portugal
                                #35
                                well glad i didn't called my client to give prices for repair .. its doing the same shit !!!!!!!but now , its not turning the dcjack led at all .. i got 3.3 on bios 3 7 and 8 pin , got same on the on off button and drop to 0 when pressed .
                                im not sure about this models if it have the power safe energy system (making the 3.3 and 5 volts coils to turn on only when the S5 state is activated by the on off button .
                                but on the coils there is nothing , but got both ldos , 5 and 3 on the main regulator .. really don't get what is the problem , it was working fine .. i was on bloody windows yesterday , now tonight before installing the Wlan card that was out of the machine i inserted the dc jack and the led was not activating and machine was not turning on .. what a pain in the ass machine .. really frustrating repair ... HP's are killing me .
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1489
                                  • portugal
                                  #36
                                  btw yesterday it was turning with adapter on ,or even just on battery mode .. both ways were working .!!! :\
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1489
                                    • portugal
                                    #37
                                    cheking schematic , like i mentioned i got both vreg's , and also i checked the U36 i got the v5al on the gates , but nothing on the drain , but i checked that the gate are connected to a transistor , were the source is connected to ground , and the gate is connected to the ALWAYS_PW_EN , so not sure about if its a PNP because i don't remember the order of the arrow must chek on google , but its if a PNP it need this ALWAYS_PW_EN to activate gate to give a 0v value or negative to make the voltage pass for the drain of the U36 making the ENTRIP to activate making the 3.3 and 5 volts coils to start working . but since there is vreg5 it would let the led of the dc jack to activate ... just taughts , here making measurement to try understand were the fault is
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1489
                                      • portugal
                                      #38
                                      ok noticed that this board dont have powersaver , when the dc jack led is on i got the coils u p with 3.3 and 5 . it all seems a problem with this AC detect thing . must be the bloody powerboard damaged. in this moment its working .. but is making the same thing , takes time for the dc led to turn on .
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1489
                                        • portugal
                                        #39
                                        Well received here another one , with a different issue ,this one blink caps lock one time , (like usual DV problem , mentioning is cpu but then its IGP . ) but this one is a intel system with HM chipset and discrete graphics , i was going to try the HP_TOOLS pen with the current and previous folder with the .FD files on each one to try recovery before trying to open it , just in case to see if its a bios problem .
                                        anyone have ever had this kind of problems on does envy's machines ?
                                        any taughts are welcome-
                                        sincerely
                                        • highpulse
                                          i hate HP
                                          • May 2013
                                          • 1489
                                          • portugal
                                          #40
                                          btw this one is a ENVY 14-2020EP BEATS
                                          i can give my original EC and MAIN dump and give the .FD file from HP for someone can split me the bios , if someone could do it , would be nice .
