820-03129 BRD
  • benberry24
    • Mar 2018
    820-03129 BRD
    Does anyone have the BRD & schematic? I'm having an issue with the fan running at %100 after cleaning up some liquid damage.
  • jkruns
    M1 A2338 screen and touchbar issues after cleaning up liquid damage
    by jkruns
    This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
    My patient is an A2338 Macbook Pro M1 (late 2020).
    It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
    04-22-2024, 06:45 AM
  • mon2
    A1466 Macbook Air (Liquid damage repair)
    by mon2
    Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
    Macbook AIR Model A1466 Diagnostic 09-01-2021
    Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
    Problems & Resolutions
    1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
    09-01-2021, 09:31 AM
  • rilley
    MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
    by rilley
    I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
    I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
    My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
    And the resistor L4004 is literally burned.
    From what I see from the schematics, it does not affect any other rails, only the connection to the display...
    07-10-2024, 01:57 AM
  • Jenzo
    MacBook A1989 overheating after liquid damage
    by Jenzo
    Hey everyone,
    Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
    I can't figure out how...
    05-13-2023, 07:58 AM
  • larrysito111
    dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
    by larrysito111
    got here a liquid damaged alienware
    the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
    so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
    so with the usb-c external monitor is getting to bios and OS
    otherwise not
    so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
    but still not the internal monitor
    (tested 3V and 5V going to the...
    06-12-2025, 04:16 PM
