Seeking boardview+schematics for Thinkpad L14 Gen 2 NM-D391 with AMD CPU
  • trepachka
    • Oct 2022
    • 507
    I have this Thinkpad L14 Gen 2 NM-D391 board with AMD CPU. It works fine off the battery but when the charger is plugged into any of the 2 USB-C ports, computer is stuck @ 5V 0A
    It does have a dual PD controller TPS65988DJ. Both inputs are showing 5V is reaching both ports. I suspect the chip is ok but rather OVP is dead and preventing the board from communicating with the charger.
    Does anyone have the boardview+schematics for this motherboard?
    Thank you
  • AL._.EX
    • Dec 2022
    • 943
    • Belarus
    Schematic & boardview
    -INVALID- files.
    • trepachka
      • Oct 2022
      • 507
      Thank you very much for that.
      Looks like chip U6301 (SN1904020YBFR) is standing between the charging port and the pd controller. I desoldered current pd controller and tested it on another board and it passed.
      • trepachka
        • Oct 2022
        • 507
        There are 2 of these on the motherboard: U6201 and U6301. I will order the chips later today and report the outcome.
        • rookieme
          • Oct 2014
          • 409
          • Greece
          did you managed to fix it?
          • trepachka
            • Oct 2022
            • 507
            I replaced them both. Same result
            • rookieme
              • Oct 2014
              • 409
              • Greece
              From a search I did it seems that TPS65988 is the one that controls the input voltage.
              If the data channels of usb don't have any brocken trace of shorted esd diode it is all about firmware for the TPS65988.
              There should be an external eeprom nearby that needs to be reprogrammed.
              I have a same case and resea.rching for a solution
              • trepachka
                • Oct 2022
                • 507
                The TPS65988 was replaced. I also placed the original chip into another motherboard and I can confirm it works. Having eeprom reprogrammed is another good idea. I just don't have the tools for it.
                • trepachka
                  • Oct 2022
                  • 507
                  I borrowed the firmware chip from a working board. No changes.Computer is still drawing 5V 0A at both USB-C ports. It runs off the battery just fine.
                  • bogart219
                    • May 2009
                    • 200
                    • usa
                    • drinking
                    Hello, have you had any luck fixing the problem? I basically have the same issue. Thanks!
                    • Sidqi Januar Riadi
                      • Dec 2024
                      • 63
                      • INDONESIA
                      reupdate please
                      • kodox
                        • Jul 2017
                        • 330
                        • Indonesia
                        • Electronic Thing
                        would you please send the files? the link is invalid, thank's...
                        • azanwaqas771
                          • Feb 2019
                          • 52
                          • Pakistan
                          why i cant download this file when i click next page open and Invalid File Specified
                            • 23624
                            Due to a server issue some months ago. The files will need reposting.
                            • luyzs
                              • Oct 2024
                              • 30
                              • Brasil
                              Hi, I couldn't identify the U6301, what would its name be so I can buy it? Thank you.
                              • pepebmx
                                ThinkPad T14 Gen 3 - Boots Only on Charger
                                by pepebmx
                                Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                                Laptop: Lenovo ThinkPad T14 Gen 3
                                Serial No: PF-437QTG
                                PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                                Extracted BIOS: Will upload tomorrow
                                BIOS Password: None Issue Description:
                                • Boots only on charger → Works normally when connected to AC.
                                • With battery connected:
                                  • Fan spins at full speed, no display.
                                  • Not all voltages present (some missing).
                                • Battery charges correctly (detected in Windows, shows percentage).
                                • When battery is plugged in while in Windows:
                                  • Laptop shuts
                                05-08-2025, 01:53 PM
                              • trepachka
                                ThinkPad E14 Gen 4 with intel processor not taking power from the charger
                                by trepachka
                                This one really stumped me. I am dealing with a ThinkPad E14 Gen 4 with Intel processor (NM-E211) that fails to take power from the charger. It had liquid damage on the board but it wasn't too bad. After cleaning, computer boots off the battery without any issues. However, when a charger is plugged in, I do get 20V/0A on the PD controller and the next on the circuit board is BQ25710 chip (PU4000). I get 20V on pin 1, 2 and 3 which is what is expected but get only 1.6V on VSYS (pin 22). REGN is showing correct 6V. I replaced the BQ chip just in case and also PQ4000 double mosfet to no avail. Pin...
                                02-26-2026, 08:37 PM
                              • Boardview and Schematic Bot
                                Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-06-2024, 11:40 AM
