Schematic need DA0PAKMB6F1 rev f
  • crot69
    • Mar 2020
    • 61
    • Indonesia
    anyone have this board schematic?
    this board is shorted in 3v or 5v (idk since i cant find ic code)
    it shorted at ic "qk=ba" (i cant find internet this ic code)
  • Grouickman
    Hofmann geodyna 6300 Wheel balancer
    by Grouickman
    Hi there,
    First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
    Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
    I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
    I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
    03-31-2025, 05:29 AM
  • sfernandes
    Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
    by sfernandes
    Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
    What I have done to try to isolate the issue so far:
    The system powers on and stays on with...
    01-23-2023, 06:03 PM
  • diamon
    Dell Latitude 5520 completely dead
    by diamon
    I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
    Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
    After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
    Have checked with a thermal camera, and there are a couple of things...
    03-05-2025, 02:23 PM
  • survivalbloke
    Surface board, main rail shorted, can't find where
    by survivalbloke
    This is MS board M1029273-001. I'm getting <.2 ohms on output of the second mosfet. Looking at a schematic, I injected 1v/5a to the resistor pin where this mosfet connects to, and it is drawing 3.7a but the only thing getting hot in the thermal camera is this resistor which surprises me.
    Where should I be looking from here?...
    09-06-2023, 03:42 PM
  • Yanleb
    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
    by Yanleb
    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
    D608, good
    D618 RF101L4S, good (See warning 1 below)
    D619 RF101L4S, good (See warning 1 below)
    D865 RF101L4S, shorted (See warning 1 below)
    IC464 Inverter HA MC74HC1G14, shorted...
    03-09-2020, 12:00 AM
