MSI GF63 12UDX-234XPT - MS-16R81 VER:2.0 - Schematic needed
    • 21876
    Originally posted by madfreak
    Hello dear all friends. Can anyone please tell me what is a IC chip PU29 on MS-16R81 VER:2.0​ board it has BFCP marking on it ? I will be truly appreciated
    post pictures of both sides of the IC
    • madfreak
      • Aug 2012
      • 135
      • Poland
      BFCP ( PU29 ) ​ It is similar to BBBJ ( PU18 ) chip and it is close to that chip on that board. - I've marked it with a yellow arrow on last picture
      • noname2024
        • Aug 2024
        • 294
        • CỎ MỸ XỊN
        IC CONVERTOR,MPS/MP1613GTL-Z,SOT583-8pin,3A SYNCHRONOUS STEP-DOWN CONVERTER WITH SS & PG,HALOGEN FREE
        • madfreak
          • Aug 2012
          • 135
          • Poland
          So the BBBR, BBBJ is the same exact chip so as the a BFCP, and those three chips are MPS/MP1613GTL-Z​ ?
          • tajdzio
            • Oct 2023
            • 3
            • Polska
            noname2024 Please help. The marked places are vias, which are corroded by the liquid on the other side. I need to know what these signals are and where they lead to, so that I can eventually pull up a new line.
            • noname2024
              • Aug 2024
              • 294
              • CỎ MỸ XỊN
              #26
              try
              • madfreak
                • Aug 2012
                • 135
                • Poland
                #27
                Dear friends can You please check me if I am thinking correct, that those values on coils are ok ? :
                The CPU is SRMAQ:
                1: 135 ohm
                2-6: 4,23 ohm
                7-8: 10,22 ohm
                • tajdzio
                  • Oct 2023
                  • 3
                  • Polska
                  #28
                  The CPU is SRMAQ:
                  1: 135 ohm
                  2-6: 4,23 ohm
                  7-8: 10,22 ohm
                  Thanks to noname2024's help, I know that my processor is working and the values ​​are as follows
                  • madfreak
                    • Aug 2012
                    • 135
                    • Poland
                    #29
                    Hello all electronic technicians fellow mates ....
                    I have received parts from china and replaced damaged ones, and that chip BFCP is exactly MPS/MP1613GTL-Z so the BBBR is the same, i have received from china BBBN which is still the same chip.
                    For the record : the resistance values of my CPU SRMAQ:
                    1: 135 ohm
                    2-6: 4,23 ohm
                    7-8: 10,22 ohm
                    Are perfectly fine, and the CPU is ok and survived a short circuit caused by a user when he tried to do a maintenance...but the RTX / graphic card did not survive it and is dead
                    Does anyone know if there is a motherboard modification ( sometimes there is a need to replace resistors ) on schematic to force LCD to display image from integrated GPU/intel rather than from RTX...because that laptop is working perfectly fine but on external monitor ...inbuilt lcd stays black
                    • alex26
                      • Sep 2012
                      • 35
                      • ROMANIA
                      #30
                      Hello friends I'm working on this MSI MS-16R81 V2.0 motherboard and I noticed that there is the U31 chip which shorts the +5 line. I removed it but I couldn't find its datasheet or the schematics of the card to replace the chip. Can anyone help me with the motherboard schematics , boardview or the chip datasheet? Thanks in advance.
                        • 21876
                        From the BOM607 spreadsheet https://www.badcaps.net/forum/troubl...07#post3536607 ,it`s SLG5NT1757V
                        • alex26
                          • Sep 2012
                          • 35
                          • ROMANIA
                          #32
                          You are right. Considering that I have already found 3 defective integrated circuits, all powered by the 5V rail, and even 2 faulty Drmos, I really need a boardview to see what other components are powering this 5V rail. I can't find a schematic or a boardview anywhere. I have another question related to these drmos. I have QD9619A on my board and I would like to replace them with SIC651CD but I don't know if they are a good replacement. Thanks.
                          • yumbo_
                            • Jan 2023
                            • España
                            #33
                            hi everyone. can anybody tell me what is PU26 and U43 in this mainboard, or please upload boardview if possible. thanks anyway
                              • 21876
                              Read the BOM file, it lists all parts - https://www.badcaps.net/forum/troubl...07#post3536607
                              • yumbo_
                                • Jan 2023
                                • España
                                #35
                                Thanks a lot.
                                • playmedia
                                  Playmedia
                                  • Jul 2018
                                  • 20
                                  • United Kingdom
                                  #36
                                  Hi, can anyone help me with the ms-16r81 v2 motherboard. I cant find a boardview so im looking for a component that has blown on the display circuit. The part isnt silk screened and blown that bad that i cant recognise it. if anyone can tell me the component or has a photo of the underside of the board it would be much appreciated. Click image for larger version
ID:	3704192 Click image for larger version
ID:	3704193 Click image for larger version
                                  • madfreak
                                    • Aug 2012
                                    • 135
                                    • Poland
                                    #37
                                    Hi, there are just two inductors. Have a nice day
                                    • playmedia
                                      Playmedia
                                      • Jul 2018
                                      • 20
                                      • United Kingdom
                                      #38
                                      Thank you Madfreak
                                      • madfreak
                                        • Aug 2012
                                        • 135
                                        • Poland
                                        #39
                                        Thank you Madfreak
                                        You are most welcome.
                                        • mohamed said
                                          • Apr 2015
                                          • 30
                                          • egypte
                                          #40
                                          pu24
                                          need this boardview
                                            MSI Gaming THIN GF63 12UCX-614NL Notebook GF Specification for Upgrade or Repair
                                            This specification for the MSI Gaming THIN GF63 12UCX-614NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the THIN GF63 12UCX-614NL boardview and THIN GF63 12UCX-614NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:19 AM
                                            MSI Gaming Thin GF63 12UCX-608AU Notebook GF Specification for Upgrade or Repair
                                            This specification for the MSI Gaming Thin GF63 12UCX-608AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Thin GF63 12UCX-608AU boardview and Thin GF63 12UCX-608AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            MSI Gaming GF63 12VF-274CA Notebook GF Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GF63 12VF-274CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF63 12VF-274CA boardview and GF63 12VF-274CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            MSI Gaming Thin GF63 12VE-206XPT Notebook GF Specification for Upgrade or Repair
                                            This specification for the MSI Gaming Thin GF63 12VE-206XPT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Thin GF63 12VE-206XPT boardview and Thin GF63 12VE-206XPT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            MSI Gaming GF63 THIN 11UCX-1420NL Notebook GF Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GF63 THIN 11UCX-1420NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF63 THIN 11UCX-1420NL boardview and GF63 THIN 11UCX-1420NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
