MSI GF63 12UDX-234XPT - MS-16R81 VER:2.0 - Schematic needed
  • camisao
    • Jan 2024
    • 11
    • Portugal
    I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
    I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
    Now it doesn't start. 😏
    I've looked for burned parts but found none.
    The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
    I need the schematic to try to understand where there the problem may be or if it is repairable.
    Thanks!
  • camisao
    • Jan 2024
    • 11
    • Portugal
    I found the laptop problem.
    The 5V output was shunted to ground.
    After some time with the multimeter I found that the problem was the USB Power switch on the port I connected that was damaged (G517).
    After removing it the 5V output was working and the laptop was able to start.
    Oredered a replacement.
    Found the datasheet for the Power Switch in the Forum.
    Thank you.
    • durango legrand
      • May 2020
      • 15
      • benin
      Hello friends I'm working on this MSI MS-16R81 V2.0 motherboard and I noticed that there is the PU24 chip which shorts the +5VSUS line and prevents the board from booting. I removed it but I couldn't find its datasheet or the schematics of the card to replace the ship. Can anyone help me with the motherboard schematics or the ship datasheet? Thanks in advance
      • phamduy221
        • Jan 2021
        • 54
        • vietnam
        IC MP1613
        CAN YOU READ ME KB9548GF 160KB ROM
        • noname2024
          • Aug 2024
          • 275
          • CỎ MỸ XỊN
          pu24
          IC CONVERTOR,MPS/MP1613GTL-Z,SOT583-8pin,3A SYNCHRONOUS STEP-DOWN CONVERTER WITH SS & PG,HALOGEN FREE
          • durango legrand
            • May 2020
            • 15
            • benin
            Originally posted by noname2024
            pu24
            Click image for larger version  Name:	2024-12-28_113204.png Views:	0 Size:	189.3 KB ID:	3536608
            Many thanks
            • durango legrand
              • May 2020
              • 15
              • benin
              Originally posted by phamduy221
              IC MP1613
              Yes i can
                • 21467
                IC MP1613
                Bios & EC - https://www.badcaps.net/forum/troubl...-12udx-bios-ec
                • phamduy221
                  • Jan 2021
                  • 54
                  • vietnam
                  Originally posted by SMDFlea
                  THANK YOU!​
                  • phamduy221
                    • Jan 2021
                    • 54
                    • vietnam
                    Yes i can
                    WHEN YOU'RE DONE IF POSSIBLE PLEASE BACK UP THE KB9548 IO ROM FOR ME PLEASE, THANK YOU
                    • phamduy221
                      • Jan 2021
                      • 54
                      • vietnam
                      pu24
                      Hello, can you tell me what the name of EC ITE is?
                      • noname2024
                        • Aug 2024
                        • 275
                        • CỎ MỸ XỊN
                        U22 CHIP,CONTROLLER,ITE/IT5571VG-128/CX,,VFBGA-128pin,EMBEDDED CONTROLLER WO/MV,HALOGEN FREE
                        • phamduy221
                          • Jan 2021
                          • 54
                          • vietnam
                          THANK YOU, I LOVE YOU
                          • ilampos
                            • Dec 2012
                            • 7
                            • GREECE
                            pu24
                            Click image for larger version  Name:	2024-12-28_113204.png Views:	226 Size:	189.3 KB ID:	3536608
                            Hello i have exact the same motherboard MSI GF63 12UC-658GR MS-16R81 VER:2.0
                            ​ with liquid damage. CAN you also recognize please chip PQ12 with broken leg (LSDL 11) and two resistors. i have arrow on image
                            Thanks in advance
                            • noname2024
                              • Aug 2024
                              • 275
                              • CỎ MỸ XỊN
                              Thanks in advance
                              PQ12 ,DIS MOSFET-N,Sinopower/SM2304NSAC-TRG,SOT23-3pin,5.1A,30V,+/-20V,35mOhm(4.5V/5A)/25mOhm(10V/8A),1.3V,1.8V,2.5V,410pF,,4nC,,HALOGEN FREE- OR DIS MOSFET-N,ALPHA & OMEGA/AOSS32334C,SOT23-3pin,6.2A,30V,+/-20V,26mOhm(4.5V/5.5A)/20mOhm(10V/6.2A),1.3V,1.8V,2.3V,600pF,,12nC,20nC,HALOGEN FREE
                              R274 RESISTOR,68.1KOhm,1%,1/16W,0402,HALOGEN FREE
                              R258 RESISTOR,10KOhm,5%,1/16W,0402,HALOGEN FREE Click image for larger version
ID:	3572045 Click image for larger version
                              • MattTheNoob
                                • Feb 2025
                                • 7
                                • Lithuania
                                How should i open the boardview ? I see it is in xls file , and my boardview program cant read it , im new to this , how could i fix it ?
                                  • 21467
                                  It isn`t a boardview, it`s a BOM, Bill Of Materials. A list of all parts
                                  • MattTheNoob
                                    • Feb 2025
                                    • 7
                                    • Lithuania
                                    Oh i see, does anyone have a boardview of this board? MS-16R81 VER:2.0
                                    • Ali milan
                                      • Aug 2024
                                      • 6
                                      • Italy
                                      can someone share the schematic of this board 16r81 please ?
                                      we need it urgently
                                      • madfreak
                                        • Aug 2012
                                        • 135
                                        • Poland
                                        Hello dear all friends. Can anyone please tell me what is a IC chip PU29 on MS-16R81 VER:2.0​ board it has BFCP marking on it ? I will be truly appreciated
                                          MSI Gaming THIN GF63 12UCX-614NL Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming THIN GF63 12UCX-614NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the THIN GF63 12UCX-614NL boardview and THIN GF63 12UCX-614NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:19 AM
                                          MSI Gaming Thin GF63 12UCX-608AU Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming Thin GF63 12UCX-608AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Thin GF63 12UCX-608AU boardview and Thin GF63 12UCX-608AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Gaming GF63 12VF-274CA Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF63 12VF-274CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF63 12VF-274CA boardview and GF63 12VF-274CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          MSI Gaming Thin GF63 12VE-206XPT Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming Thin GF63 12VE-206XPT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Thin GF63 12VE-206XPT boardview and Thin GF63 12VE-206XPT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          MSI Gaming GF63 THIN 11UCX-1420NL Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF63 THIN 11UCX-1420NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF63 THIN 11UCX-1420NL boardview and GF63 THIN 11UCX-1420NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
