Hi, need boardview or schematic on MS-14DK1 board
MS-14DK1 brd or schematic
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by Garret Matt.Hello,
I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
Thank you in advance for any assistance you can render.
Inductor In question. Buzzes like...-
Channel: Schematic Requests ONLY!
06-20-2025, 01:21 PM -
by johnbetonHello,
I'm looking for the schematic for a Acer board Yacht_TL 203022-1
The board had some minor liquid damage.
I have no shorts, have 3v, 5v, 3.3v, ... but no leds or power on.
When touching certain parts of the board with my finger, the powerleds go on or start blinking.-
Apple MacBook Pro 13" A1706 Logic Board 820-00923 Schematic & Board View...
Channel: Schematics and Boardviews
- Loading...
