Dell Studio 1558 fm9c schematic needed
  • bucephalus
    • Mar 2016
    • 22
    • India
    Re: Dell Studio 1558 fm9c schematic needed
    +15v_alw is absent why? on page 46
    ICH_RSMRST+ is 0v goes to 3v when power button is pressed then again goes to 0v in 1/2 second
    SIO_SLP_S5# goes from 0v to 1v then again 0v
    please reply!
    • bucephalus
      • Mar 2016
      • 22
      • India
      Originally posted by lezsimply
      this also happened to me on a dell 1525. rsmrst and s5_enable won't give voltage after pressing the power button. All I did was programmed bios and unit came alive.
      did you programmed 1mb flash or both 1mb and 4mb flash.
      • bucephalus
        • Mar 2016
        • 22
        • India
        UPDATE
        After pressing power button several times. Motherboard turned on but the CPU fan was not spinning. CPU heatsink was getting hot. No display.
        +3.3v_alw-> coil PL9
        +5v_alw -> coil PL10
        +5v_alw2 ->TPS51427a LDO pin 7
        +15v_alw--is only 13.1v PQ43 page 46
        +3.3v RTC
        +5v_RUN -> PQ14
        +3.3_SUS -> PQ15
        +5v_SUS -> PQ17
        +3.3v_RUN -> PQ22
        +3.3v_DELAY -> R424 Page 17
        +1.5V_RUN -> PQ11
        ALL PRESENT
        RSMRST 3.3V ->ITE8502E pin 80
        i will check gfx voltage and CPU Voltage and post the results.
        COULD THIS STILL BE A BIOS ISSUE. Or ATI Graphics chip issue.
        Please help.
        Any help would be much appreciated
        • bucephalus
          • Mar 2016
          • 22
          • India
          Update
          +1.05v_PCH on PL8 coil is present
          • bucephalus
            • Mar 2016
            • 22
            • India
            Finally success
            laptop turned on with display and all features
            • cvorke
              • Oct 2012
              • 26
              • Solar system
              #26
              Originally posted by bucephalus
              Finally success
              Could you please share with us, where was the problem, and solution?
              • mojtaba12
                • Aug 2016
                • iran
                #27
                Could you please share with us, where was the problem, and solution? i have the same problem
                • adm64
                  • Oct 2016
                  • Cyprus
                  #28
                  Thank you for schematic of this laptop. I've managed to fix my laptop using it.
                  In my laptop the similar problem was related to faulty GPU temperature reading by ADM1032ARMZ-1 chip. It was blocking the laptop from start.
                  • jellytot
                    • Mar 2015
                    • 42
                    • Ireland
                    #29
                    Hi ADM64. Exactly the same fault on my unit..Thank you for your post.
                    • canali
                      • Oct 2014
                      • 194
                      • turkey
                      #30
                      thank you
                      • fyaagoub
                        • Dec 2016
                        • 269
                        • maroc
                        #31
                        thank you
                        • CIB-TECH
                          • Oct 2016
                          • 14
                          • algeria
                          #32
                          • Noreddin
                            • Jan 2020
                            • 73
                            • mostaganem
                            #33
                            thank you
