MSI Creator Z16 A11UET MS-15711 607-15711-14S Schematic/Boardview
  • BlueMidnight
    • Jan 2015
    • 489
    Does anyone have a schematic, boardview, or any other related information about the MSI Creator Z16 A11UET MS-15711 607-15711-14S?
    Even information about similar boards would be useful. Thank you.
  • jasontaylor1974
    • Jun 2025
    • 4
    Did you ever get a schematic and boardview file for this one? I need the same ones. If so please let me know where I can get them. Thanks
    • noname2024
      • Aug 2024
      • 291
      • CỎ MỸ XỊN
      bomfile
      • jasontaylor1974
        • Jun 2025
        • 4
        Originally posted by noname2024
        bomfile
        Thank you noname2024 for the BOM it is very helpful. I sill I am looking for the boardview file and schematic. Any chance you have them or know where I can locate them?
        • noname2024
          • Aug 2024
          • 291
          • CỎ MỸ XỊN
          What information do you need? Click image for larger version
          • jasontaylor1974
            • Jun 2025
            • 4
            I am needing the boardview file so i can use it for working on this board. Can you post it or tell me where i can get it from?
            • TheDando
              • Feb 2023
              • 36
              Yup need the boardview and schematic as well if anyone has it....
              • TheDando
                • Feb 2023
                • 36
                Hey guys I'm looking for the Boardview and Schematic for a MSI Creator Z16 A11UET MS-15711 VER 1.0 or very similar models. Hopefully someone here has it,Thanks in advance.
                  SMDFlea commented
                  Editing a comment
                  Thread merged. There is no need to start a new thread.....
              • PacoGT
                HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                by PacoGT
                hello firends
                i search the schematic or boardview
                I have this motherboard, but I can't find the schematic or the boardview.
                The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                So the computer doesn't turn on, and the 3V disappears after a few seconds.
                The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                The new problem arose after removing the bad chip.
                3V and 5V remained together,...
                08-19-2025, 08:25 PM
              • hosain0489
                Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                by hosain0489
                I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                Thank you very much in advance!
                07-15-2025, 11:20 AM
              • re-atari
                Gigabyte GA-H110-D3A schematic/boardview needed
                by re-atari
                Hello all,
                Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                02-24-2025, 06:45 PM
              • jonyhdtv
                HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                by jonyhdtv
                Looking for schematic and boardview
                Model: HP ProBook X360 11 G3 EE
                Serial: SCG9114JG7
                Motherboard: L43774-601
                defect: touchscreen doesn't work (touch works on another computer)
                thanks to all​
                01-29-2025, 08:16 AM
              • jonyhdtv
                HP ProBook X360 11 G5 ee schematic and boardview thanks
                by jonyhdtv
                HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
                Model: HP ProBook X360 11 G5 EE
                Serial: SCG0164QLH
                Motherboard: L83950-601
                defect: no POWER
                thanks to all​
                01-29-2025, 08:11 AM
