MSI S262 schematic
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    MSI S262 schematic
    Good day guys, I need schematic diagram for this old mega book from MSI, model S262, board code: MS-10571 ver: 4.0
    Laptop turns on but there's no display. Fan clicks a little then stops, but does not turn off laptop. Thanks!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: MSI S262 schematic
    only sch i have found
    Im Back... sort of...
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      That was quick man. Thanks very much! I wonder where you found it
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        np
        here you go, only 2 dowloads per day
        http://elektrotanya.com/?q=showresult
        for msi, i would try to reprogram bios, often fails on msi
        • lezsimply
          The Wanderer
          • 657
          • Philippines
          I see, I tried to search there but 0 results, maybe because of wrong inputs. You are correct regarding bios, I fixed a lot of msi wind netbook which involves bios. I'll post results after I reprogram bios. Thanks very much
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            based on your description on the issue, i suspect it's the GPU. take mild reflow and test.
            • lezsimply
              The Wanderer
              • 657
              • Philippines
              I'm with you fd, the owner told me his kid was always playing dota on it. I already had this laptop cleaned 3 years ago.
              I haven't touched it yet because I was summoned somewhere else for an emergency maintenance. I'll update you asap. Thanks!
              • lezsimply
                The Wanderer
                • 657
                • Philippines
                This laptop needs reballing, I did a lite reflow and it worked. Now I know graphics chip is the problem. I never really liked reflow jobs so I'll send this to my uncle for reballing coz I can't do it here. Thanks people!
                • lezsimply
                  The Wanderer
                  • 657
                  • Philippines
                  Laptop worked for a couple days after reball. And now it does the same thing. when power button is pressed fan spins a little then stops. power is still on. Also notice when I remove processor then try to power the laptop fan spins but never stop. any thoughts?
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5076
                    • New Zealand
                    Probably the chip is stuffed, the early batches were bad, the chip fails and reflow\reball won't fix it - but you might think it did because when you move the heatsink it can make the contacts work for a short time. Check the datecode... there are posts on the forum here about which dates are bad.
                    -David VanHorn
                    • lezsimply
                      The Wanderer
                      • 657
                      • Philippines
                      Thanks agent, I'll check the code. The odd thing is I get 0 volt on PL4 and PL5 (vhcore) when I try to power laptop with processor on it. If I remove processor I got 1.40v on both coils which gradually going down.
                      • lezsimply
                        The Wanderer
                        • 657
                        • Philippines
                        need bios file for this one. hope someone has. thanks
                        • lezsimply
                          The Wanderer
                          • 657
                          • Philippines
                          anyone?
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            http://www.msi.com/product/nb/S262.html#/?div=BIOS
                            • lezsimply
                              The Wanderer
                              • 657
                              • Philippines
                              Thanks ala, I already tried those bios from website but sadly nothing works. If bios won't fix the issue, I guess I've got send this back to the owner.
