LA-J891P Schematic & Boardview
  • aico60
    • Nov 2022
    • 30
    • Bulgaria
    Attaching schematics and boardview.
    Note: Schematics is for rev 0.1 as I could not find one for REV 1A (but there are some changes noted at the bottom of the file so might contain components for rev 1A)
  • aaron7
    • Aug 2017
    Wanted to thank you for this post!
    • bzzt
      • Jun 2023
      • 11
      • Netherlands
      Thanks for sharing, much appreciated.
      • pacwcbs
        • Nov 2015
        • 28
        • Dominican Republic
        Thanks for sharing
        • gary_5719
          • Nov 2021
          • United Kingdom
          Thankyou!
          • lp_ganibal
            • Nov 2019
            • Kyrgyzstan
            THANK U
            • bood
              • Mar 2021
              • 7
              • Ukrainien
              Thankyou! 🤝🤝🤝
              • Dark_Angel
                • Oct 2012
                • 10
                • Portugal
                Thank you very much!!👍
                • prado_user_120
                  • Nov 2023
                  • 8
                  • Kazakhstan
                  • stavvy
                    • Oct 2025
                    Thanking Thee👍
                    • PacoGT
                      HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                      by PacoGT
                      hello firends
                      i search the schematic or boardview
                      I have this motherboard, but I can't find the schematic or the boardview.
                      The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                      So the computer doesn't turn on, and the 3V disappears after a few seconds.
                      The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                      The new problem arose after removing the bad chip.
                      3V and 5V remained together,...
                      08-19-2025, 08:25 PM
                    • hosain0489
                      Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                      by hosain0489
                      I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                      Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                      If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                      Thank you very much in advance!
                      07-15-2025, 11:20 AM
                    • re-atari
                      Gigabyte GA-H110-D3A schematic/boardview needed
                      by re-atari
                      Hello all,
                      Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                      This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                      02-24-2025, 06:45 PM
                    • jonyhdtv
                      HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                      by jonyhdtv
                      Looking for schematic and boardview
                      Model: HP ProBook X360 11 G3 EE
                      Serial: SCG9114JG7
                      Motherboard: L43774-601
                      defect: touchscreen doesn't work (touch works on another computer)
                      thanks to all​
                      01-29-2025, 08:16 AM
                    • jonyhdtv
                      HP ProBook X360 11 G5 ee schematic and boardview thanks
                      by jonyhdtv
                      HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
                      Model: HP ProBook X360 11 G5 EE
                      Serial: SCG0164QLH
                      Motherboard: L83950-601
                      defect: no POWER
                      thanks to all​
                      01-29-2025, 08:11 AM
