Motherboard schematic VLAD10-6050A3261101-MB-A01 (A1) For HP Laptop 17-cn0023dx. Board also references 17N-8L-TGL
I'm am looking for schematics for HP 17-cn0234ng (Motherboard 6050A3261101)
So I got a Laptop with no sign of life. No light, no reaction to power button but 4mA of current draw.
Main power rail was present but all other voltages where missing. Coils measured ok.
I located 3.3v regulator and injected low voltage and found a heat spot near the lid sensor. I could narrow it down to a resistor that was getting hot. I removed it and it measured around 60ohms. No clue what it is doing or if that's the right value even. So schematics would help.
I removed the resistor and the laptop has now charging light and is even charging the battery. It is reacting to power button now and tries to start. Chip set is coming up (getting warm under Thermal cam) and taking 50mA.
But no picture , no Vcore and no RAM voltage.
I want to find out what the resistor I removed is supposed to do. I have a feeling it's related to the chip set unfortunately...
Any help or thoughts are highly appreciated :-)Comment
by fafa_bxlHi guys, does anyone have the schematic / board view for Gigabyte G5 KF laptop - 6-71-NP5PR0-D01 motherboard ?
I really appreciate !-
Channel: Schematic Requests ONLY!
04-22-2025, 02:58 AM -
Asus M52V (Pegatron G60VX Motherboard) Laptop Schematic Rev 1.2...
Channel: Schematics and Boardviews
11-06-2024, 06:40 AM -
Asus K93S K93SV X93SV X93S Laptop Motherboard PBL80 Schematic...
10-04-2024, 04:11 AM -
by neandertoolHi, hoping someone can help me out with this one. My laptop just died and I really need to get it fixed. Thanks in advance!
by Geeker007Hi All,
So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
I have not tried putting... - Loading...
