Schematic HP DV7-1120 needed
  • vinkos
    • Jul 2013
    • 51
    • Netherlands
    Halo,
    I need schematic for dv7-1120.
    Thanks in advance !
  • jtamad44
    • Apr 2013
    • 145
    • israel
    Re: Schematic HP DV7-1120 needed
    what is the motherboard code?
    • vinkos
      • Jul 2013
      • 51
      • Netherlands
      486541-001
      jbk00 la-4092p
      • jtamad44
        • Apr 2013
        • 145
        • israel
        Originally posted by vinkos
        486541-001
        jbk00 la-4092p
        sorry body, I have only jbk00 la-4093p
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          here
          Im Back... sort of...
          • vinkos
            • Jul 2013
            • 51
            • Netherlands
            Borba,
            Thanks !
            • warttan
              • Feb 2014
              • romania
              thx for the files
              • knk2729
                dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
                by knk2729
                06-23-2025, 07:09 PM
              • Ven
                Dynabook Satellite Pro L40-G-102 Schematic Needed
                by Ven
                Dynabook Satellite Pro L40-G-102 Schematic Needed.
                02-24-2025, 06:21 AM
              • re-atari
                Gigabyte GA-H110-D3A schematic/boardview needed
                by re-atari
                Hello all,
                Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                02-24-2025, 06:45 PM
              • camisao
                MSI GF63 12UDX-234XPT - MS-16R81 VER:2.0 - Schematic needed
                by camisao
                I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
                I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
                Now it doesn't start. 😏
                I've looked for burned parts but found none.
                The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
                I need the schematic to try to understand where there the problem may be or if it is repairable.
                Thanks!...
                12-02-2024, 05:30 AM
              • Gau_saha
                Schematic needed GA-H61M-S REV1.1
                by Gau_saha
                Sir ,
                I need the schematic of h61m-s rev1.1 gigabyte motherboard.
                Recently this board came to me for repair but could not find its schematic .
                The problem of this board is no display but the board has a power on it .Processor is not heating .
                For preliminary investigation i changed vga cable ,ram and processor but the same issue persist.
                Whenever i switch on the motherboard monitor says NO SIGNAL .
                The board is almost new .No sign of corrosion on the board seen .
                10-16-2024, 08:48 AM
