need schematic . thanks
Dk10fg-6050a2491301-mb-a02
Re: Dk10fg-6050a2491301-mb-a02
check here, iam to lazy to register for download:
http://www.elvikom.pl/forum/viewtopic.php?p=95001
or
http://eletronicabr.com/gerenciador-...akar10fg/8265/Comment
thanks @robrock1Comment
I have a L855-11K Toshiba with this MB, (DK10FG-6050A2491301-MB-A02) The power was applied with reverse polarity.
I downloaded the schematic and it is the correct one but I am noob at reading schematics and it is very confusing. Could anyone with experience direct me to the component that would have been damaged? I am not seeing any burned out Mosfets or diodes and both fuses test ok. I don't understand the schematic as the voltage is not listed.
Thanks in advance.Comment
i know this is old post but thamkyou for board view. best regards jamesComment
Toshiba Satellite C850 C855 Laptop Schematic
6050A2509701-MB-A03
C855D-S5104
C855D-S5340...-
Channel: Schematics and Boardviews
11-01-2024, 04:38 AM -
by coinwizxThe power supply is 2024 newest version of NZXT C850 modular power supply.
Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then... -
by coinwizxHi,
Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts... -
by ktmmotocrossOn RX7xxx is use controllers from MPS. on their page it is app to monitor this controllers. but accout must be registered from corporate mail. Can anybody register, download and share this app
https://www.monolithicpower.com/en/c...al-login-popup - Loading...
