510s-13ikb Lenovo
  • judie
    • Mar 2023
    • Sverige
    510s-13ikb Lenovo
    Hi!
    Does any on happen to have schematic / boardview for this computer.
    I think I need to know where the screen back light fuse is.
    The computer works with HDMI on a external screen and I can see the info on the internal screen if I use a flashlight on it.
    BR
    /Kalle
  • AL._.EX
    • Dec 2022
    • 896
    • Belarus
    Re: 510s-13ikb Lenovo
    Platform???
    • BMCappelletti
      Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
      by BMCappelletti
      Hi everyone.
      Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
      Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
      Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
      02-18-2025, 12:22 PM
    • ahoonid
      MacBook A1990 vertical stripes on external screen
      by ahoonid
      Hey everyone,
      I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
      The board is neat. Not opened before for sure. Just a little dust, nothing more.
      Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
      06-20-2025, 08:54 AM
    • g1150
      Lenovo G565 Laptop , LCD not turn on, external terminak ok.
      by g1150
      Lenovo G565 Laptop onboard LCD Display does not turn on.
      Only works with external Monitor.
      I am trying to verify that the LCD signals from the motherboard are ok.
      The LCD was working, but over time happened to not turn on more frequently.
      Now dead.
      Possibly the cable from MB to LCD is broken somewhere.
      I just wonder how it is detected if external or internal monitor shall be activated ?
      I found the following schematic on the net:
      Problem 2:
      The graphics chip ATI Mobility Radeon HD5470 seems defective.
      On Win7...
      05-07-2025, 11:51 AM
    • survivalbloke
      HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
      by survivalbloke
      SN: 8CG0213H8W
      ProdID 3C311UA
      This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
      05-08-2025, 12:21 PM
    • viniciussls
      Notebook won’t turn on after screen replacement - Lenovo Legion Silm 5 16IRH8_LOQ 15IRH8 Compal ILG10 LA-M542P Rev 1.0
      by viniciussls
      Good morning everyone, this is my first post and I apologize in advance if there are any mistakes in the post.
      I have a Lenovo Legion Slim 5 16IRH8_LOQ with the typical issue of stripes on the screen, but I made the mistake of replacing the screen without physically removing the battery, thinking that just pressing the SW2 button would be enough – it wasn't. The board showed consumption, with LED6301 lit up and PU301 getting very hot. I replaced PU301. Now, the board is not working correctly, but it has no consumption, LED6301 stays on, and I haven't found any other signs of a short...
      04-02-2025, 01:40 AM
