HP 15s-eq1117AU DA0P5GMB6G0 REV:G
  • zurvanielle
    • Feb 2017
    • 137
    • Philippines
    halOoh Guys..... Good day.....^_~
    Looking for a schematic diagram or boardview for
    anyone who got, please share....
    thank u in advance....^_~
  • pooya_pm
    • Jan 2021
    • 254
    • iraq
    Re: HP 15s-eq1117AU DA0P5GMB6G0 REV:G
    Originally posted by zurvanielle
    halooh guys..... Good day.....^_~
    looking for a schematic diagram or boardview for
    hp 15s-eq1117au da0p5gmb6g0 rev:g
    Thank u in advance....^_~
    check this
    • zurvanielle
      • Feb 2017
      • 137
      • Philippines
      Originally posted by pooya_pm
      check this
      Thank you for the quick response.....^_~
      it help me a lot.... ^_~
      • renald21
        • Sep 2020
        • 27
        • Philippines
        hi do you have schamatic diagram of this unit?
        • hs5424
          Dynacord powermate 1600 block diagram.
          by hs5424
          Hi All,
          I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
          The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
          07-31-2025, 01:35 PM
        • gabri2211
          I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
          by gabri2211
          hello everyone, I'm looking for the wiring diagram of this led monitor.
          the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
          I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
          I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
          thanks to those who will answer
          12-10-2024, 04:37 PM
        • justice171
          JVC LT-50N795 Stuck on Wisdom Share Logo
          by justice171
          I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
          It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
          Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
          Thanks in advance!
          11-04-2024, 02:55 AM
        • ngngocson113
          I need bios asus tp301u ( uma ( vga share))
          by ngngocson113
          hi everyone
          i need bios asus tp301uj ( "uma " vga share)
          my mainboard doesn't use vga chip and it uses vga together with cpu.
          I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
          thanks everyone....
          09-25-2025, 02:20 AM
        • Microeletronica
          HP foxconn 115xdbp 86dr motherboard bios and electrical diagram
          by Microeletronica
          I need the electrical diagram and bios for the HP foxconn 115xdbp 86dr board, does anyone have it?
          09-10-2025, 07:57 AM
