iPad 6th gen A1893
  • MaineFix
    • Jan 2023
    • 17
    iPad 6th gen A1893
    I'm looking for the board view and schematics for A1893 cellular iPad 6.
    I removed the motherboard and did a charging port replacement on the device and and I put it back together the power button works but not the volume buttons. I then replaced the power/volume flex and this didn't have any affect on fixing the issue. Is there anything you would suggest? The client also didn't mention anything about this when it was dropped off.
    Any and all help is greatly appreciated thank you.
  • mon2
    • Dec 2019
    • 13846
    Re: iPad 6th gen A1893
    See attached. This is for the 820-00996 / 820-01327 logic boards.
    Confirm that the filter parts (ferrite beads) are not damaged or missing.
    You can do a resistance check from one side of the connector to the other side of these 3 coils.
    • univers73
      • Nov 2020
      • 13
      • france
      I need to replace this capacitor on a 820_01327, can anyone tell me what it is ?
      Thanks by advance.
      GP
      • assembly
        • Apr 2021
        • france
        Could you upload the schematic and components pdf?
        • mferna14
          • Jun 2018
          • 1009
          Can someone share the schematic/Boardview of this iPad A1893 (6Th Gen). I wan replacing the Tristar & I aired out one of the resistance. Can anyone please inform me the value of the marked missing resistance/component in the photo attached. Thanks in adavance.
          • mferna14
            • Jun 2018
            • 1009
            Never mind dears. the component is a 4.7K Resistor & it's for the ENABLE signal of this Tristar. This is why the iPad was not charging. I soldered another one & all works fine. Charges well & iPad works fine. In the near future I will load a jpg & list the components with their values by the four side of the TRISTAR chip because many of the tech replace the Tristar & knock/blow out off components accidentally. Thanks
            • SolderNewbie
              IPAD 6 (2018) A1893 No power
              by SolderNewbie
              I'm trying to fix an IPAD 6, 2018, A1893 WIFI.
              It does not turn on and does not enter recovery or dfu mode.
              History
              The device was working before, but did intermittently reset.
              I gathered two panic logs:
              "panicString" : "Attempting to forcibly halt cpu 0\ncpu 0 failed to halt with error -5: halt not supported for this configuration
              "panicString" : "panic(cpu 0 caller 0xfffffff020e14724): nvme: "AppleEmbeddedNVMeController. Controller fatal bit set. Write.
              I attempted an IOS update to the newest...
              12-21-2024, 03:50 AM
            • GeirAndersen
              iPad .pcb file collection
              by GeirAndersen
              I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
              Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
              IPAD COLLECTION 1
              +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
              +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
              +---iPad mini3 820-00008(A1599) 820-00002(A1600)
              +---iPad mini4 820-00180(A1538) 820-00177(A1550)
              +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
              +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
              12-09-2024, 09:28 AM
            • wetpretzel2
              820-02273 iPad Air 4 (Cellular) board view
              by wetpretzel2
              Does anyone have a board view or schematic for this model? Got a case of iPad not working after traveling abroad. need a board view to know what's getting hot, or warmer than everything else.. TIA
              08-08-2024, 11:54 PM
            • karthur
              Vizio D65x-G4 Volume changes on its own
              by karthur
              On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
              It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
              06-05-2025, 08:13 AM
            • grimacelord
              Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
              by grimacelord
              Hello.
              Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
              If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
              For example, when I connect the iPad to...
              04-15-2022, 11:06 AM
