please help remove password dell lat.5320-8fc8
  • ELOUALI
    • Mar 2022
    • 45
    • BLANCA
    #161
    Originally posted by hoaca388
    Update bios, see if it goes from 62LTJL3-0001 to 62LTJL3-8FC8.
    OK, thanks, I'll try this tip and you'll get my feedback.
    • ELOUALI
      • Mar 2022
      • 45
      • BLANCA
      #162
      Hello, I just tested the file, but it didn't work (the machine boots without any BIOS errors) but it doesn't display any images.
      For the original BIOS, I think there was a master code lock option that was enabled. That's why the suffix, instead of being 8fc8, was converted to 0001, and that's what caused the problem, I think.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12234
        #163
        0001 is the old suffix, 8fc8 is the new suffix.
        Try clear ME file. Give it at least 30 minutes.
        • ELOUALI
          • Mar 2022
          • 45
          • BLANCA
          #164
          I have an update for my case:
          The original chip is w25r256jven, on my workbench I have another chip with ref: w25q256jven with which I test the files or in case there will be a dump problem I only put back the original chip that I removed, so so far everything is fine, I did some research and I saw that there is a difference between w25q and w25r so I looked for a w25r in my junkyard and I found one, the weird thing in all this is that when I dump the original chip and I put it on the w25r the machine starts and goes into screen test mode and when I remove it and I put the original chip the machine starts normally and accesses windows without any problem, the dump I checked several times with verty and rt and it is identical, if anyone has an explanation?
          • ELOUALI
            • Mar 2022
            • 45
            • BLANCA
            #165
            Hello, I followed your instructions, but unfortunately after a while the machine turns off by itself and nothing happens.
            If anyone has an explanation for my case, I would be grateful. Why when I rewrite the dump extracted from the bios chip on a new one with the same reference, the machine instead of booting on Windows, it boots in screen test mode?
            • ELOUALI
              • Mar 2022
              • 45
              • BLANCA
              #166
              Unlocked
              Update: First of all, I thank you for your kind generosity and I want to inform you that this file has been fully functional since the beginning. The mistake I made and realized later is that you should not change the original chip for another one even if they are identical, they can cause problems for a reason that I do not know until now, I got used to not rewriting on the original chip to avoid a bad extracted file and that's where it all started.
              Finally, I thank all the great people I met here, you are truly the best.
              • MrShinyX
                • Aug 2025
                • 6
                • England
                #167
                Hi guys,
                I have a Dell Latitude 5320 that i have forgotten my BIOS admin password on, is there anyway to get a master password or would it be reading the BIOS chip manually?
                Service tag: 6PKWCL3-8FC8
                Thanks in advance
                  SMDFlea commented
                  Editing a comment
                  Thread merged.
              • shiyab
                • Sep 2023
                • 1581
                • india
                #168
                Originally posted by MrShinyX
                Hi guys,
                Thanks in advance
                ss post backup bios
                • MrShinyX
                  • Aug 2025
                  • 6
                  • England
                  #169
                  Originally posted by shiyab
                  ss post backup bios
                  i have my ch341a kit coming tomorrow, i will create a dump and post here. thank you
                  • MrShinyX
                    • Aug 2025
                    • 6
                    • England
                    #170
                    ss post backup bios
                    Sorry for the delay, just wasnt not able to get around it till today. find the bin file attached. would really appreciate it if it can be unlocked.
                    Thank you in advance
                    • LBTT1121
                      • Nov 2024
                      • 687
                      • Việt Nam
                      #171
                      Backup Bios 32Mb , 25Q256......
                      • MrShinyX
                        • Aug 2025
                        • 6
                        • England
                        #172
                        the back up is 1Mb, not 32Mb? its a 25Q80DV
                          • 21582
                          The 25Q80DV chip is 1MB ,it`s for the thunderbolt firmware.
                          • MrShinyX
                            • Aug 2025
                            • 6
                            • England
                            #174
                            My apologies. I am new to this...
                            I though this was the BIOS chip. Which chip would i be looking for?
                            • Rivomanana
                              • Aug 2025
                              • Andorre
                              #175
                              please help remove bios password dell lat.5320
                              • peste
                                • 13321
                                • ROMANIA
                                #176
                                post S/T, full name and model, motherboard model,post the original contents of the bios chip..
                                etc.
                                • FORESTUK2001
                                  • Sep 2025
                                  #177
                                  Hi, I need some help unlocking a bios on a 5320 the service code is F83P3B3-8FC8 any ideas of how to go about this? thanks
                                  • LBTT1121
                                    • Nov 2024
                                    • 687
                                    • Việt Nam
                                    #178
                                    post ST,post the original contents of the bios chip..,,etc.
                                    • elfb
                                      • Sep 2025
                                      • France
                                      #179
                                      please help me remove password bios dell latitude 5320
                                      how can I extract the file you need from my bios ?
                                      thanks
                                      • peste
                                        • 13321
                                        • ROMANIA
                                        #180
                                        thanks
                                        post S/T, full name and model, motherboard model, etc.
                                        post the contents of the bios chip even if it is corrupted..
                                        The bios chip must be unsoldered from the board before writing or reading..
                                        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                        solder wires between the programmer and the bios chip..
                                        you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHow​
