Hp probook 600 g2 Fans are working no picture ?
  • bruce35
    • Mar 2022
    • 41
    • turkey
  • bruce35
    • Mar 2022
    • 41
    • turkey
    Re: Hp probook 600 g2 Fans are working no picture ?
    working done
    • Bazfletch3
      Panasonic TH-65FX800A backlight LED's working but picture is very dark
      by Bazfletch3
      Hi all
      While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
      I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
      From there I envisaged that the backlighting wasn't working, however...
      01-08-2024, 10:18 PM
    • markobi
      HP Probook x360 11 G6 EE working bios is needed
      by markobi
      Hello everyone. I have this probook x360 11 G6 ALOE20 6050A3113201-MB-A01(A1). It has computrace and I need a working bios to get it working back to normal. I can really lay my hand on any bios file yet. My original bios file is also attached. Thanks in advance....
      09-02-2023, 02:38 AM
    • emil_t
      RTX3090 working fine but fans not spinning
      by emil_t
      Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
      04-12-2024, 06:54 AM
    • Ierwin
      Philips 58PUS7805 Menu working but no/weird picture from video sources
      by Ierwin
      I got a 58pus7805 that shows some weird behavior.
      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
      I managed to install the latest official firmware by holding the control button while plugging...
      03-10-2024, 12:50 PM
    • hendue
      LG 49UF6409 No Picture, Backlight & Sound working
      by hendue
      so my TV recently decided to stop working.
      At first, it sometimes showed just one color on screen after switching it on, but as far I remeber the menu still worked.
      Now theres no way to get it to that anymore, just a blank screen :/
      I've already tested unplugging either the right or left cable from the TCon to the panel, but neither halves of the TV had a picture (see attached files). The white half is always on the unplugged side, the other side stays blank.
      With the right cable unplugged, the right side faded to grey after leaving...
      02-12-2024, 03:33 PM
