Alienware m17 i7 9750h rtx2060 bios
  • Lsx
    • Nov 2022
    • 5
    • Usa
    During the bios update it laptop froze and is dead now. Except power light.
    I found this on motherboard orion mb n18e rev A00
    And eeprom winbond 25q128jvsq this should be 16mb chip that hold bios.
    I ordered ch431a programmer and planning to try to flash the eeporm directly so need bios dump.
    Attached exe and .rcv of version that was current on the laptop before failure (downloaded from dell)
  • hardware1
    • Sep 2021
    • 2936
    • N/A
    Re: Alienware m17 i7 9750h rtx2060 bios
    We will need your original bios file, read the 25q128jvsq chip with a programmer and upload it here. Also write your device service tag.
    all donations are welcome,
    • Lsx
      • Nov 2022
      • 5
      • Usa
      Expecting to receive programmer on Sunday. Will read chip and upload. Thanks. Service tag is jp6sn42
      • Lsx
        • Nov 2022
        • 5
        • Usa
        Read my chip. Here is file.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11798
          Alienware m17
          Service Tag: JP6SN42
          • Lsx
            • Nov 2022
            • 5
            • Usa
            It's booting to recovery now. Thank you ... it did take some time to display anything but I realized i should wait as fans were spinning which wasn't the case before. After 2min it showed recovery screen.
            If it's not the secret, what you had to do with the file to fix it.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11798
              I replaced the old bios region with the extract from the .exe file (downloaded from the Dell homepage), removing some padding.
              • Debric
                • Nov 2020
                • 23
                • Philippines
                Alienware m17_service tag 1NBQN42
                Hello, would like to seek help for a clean bios bin for my alienware m17. no display but with power. attach is the backup bin file.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Re: Alienware m17_service tag 1NBQN42
                  Try:
                  Become a Badcaps supporter
                  Thanks to all supporters.
                  • Debric
                    • Nov 2020
                    • 23
                    • Philippines
                    Originally posted by Vesko356
                    Try:
                    Thanks @Vesko356. i'll try to flash this bios bin you gave.
                    • Debric
                      • Nov 2020
                      • 23
                      • Philippines
                      by the way prior flashing, i did check thru ME analyzer.
                      this is what i observed...pls see pic... a lot of invalid errors.
                      do you thinks that is OK?
                      my orig backup does not have that one...
                      • Debric
                        • Nov 2020
                        • 23
                        • Philippines
                        i still did try flashing the new bin file, but same case with power but no display. thanks
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          After I submit a file I should have checked it, and I always do, simply because I am a perfectionist by nature. You don't need to check my work further, or if you think you have more knowledge than me, you can make your own dump.
                          Your ME Analyzer version is old, hence the errors you see.
                          I'm afraid your problem is not bios related then, but rather is a hardware issue.
                          • Debric
                            • Nov 2020
                            • 23
                            • Philippines
                            @Vesko356, thanks for this wonderful feedback and i truly respect your knowledge on this. sorry if it find unusual to you on what i did thru checking via ME analyzer. i dont have any bad intention on this since i am still learning on this workaround. i just learn recently on youtube about this ME analyzer so now it gives me the idea when to flash a bin file because i usually make a trial and error on flashing a bin file that is downloaded from net like here in this forum (dismount and mount the SPI chip) and i want to save time on doing this. and thank you again for letting me know about the outdated version of this ME analyzer.
                            Yes, maybe you are right. it seems this unit i am trying to get fix is not on the bios issue, it could be on hardware already and for that im gonna stop my workaround until bios testing..
                            Thank you very much for the time and effort in giving support.
                            • drux
                              Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                              by drux
                              I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                              Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                              These models have AMI/Aptio BIOS.
                              Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                              11-03-2024, 01:18 AM
                            • maciek1221
                              Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
                              by maciek1221
                              Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
                              Config:
                              Model: Asus G512LV-HN235T
                              Platforma: G532LWS rev. 1.3
                              CPU: intel i7-10870H
                              GPU: nVidia Geforce RTX2060/...
                              03-07-2024, 07:54 AM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • Mr.Ultimate
                              Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
                              by Mr.Ultimate
                              Hi everyone, hope to get someone to help and modify bios rom for me.
                              I need to disable dedicated nvidia graphics chip permanently.
                              GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
                              Ideally if it was disabled from bios at preboot.
                              I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
                              08-06-2024, 05:15 AM
