Re: Need LenovoLegion 5-15IMH05H NM-c911 bios Clean dump
https://download.lenovo.com/consumer...s/efcn52ww.exe
DMI location 532000 - 533FFF (hex lenght 1000) , or search the dump for LENV. You can copy\paste the DMI data at the mentioned address from your dump to the virgin file below.
Need Lenovo Legion 5-15IMH05H NM-c911 bios Clean dump
Does anyone have the EFCN52WW bios for me to try on my laptop?? version .BIN because the 58ww does not start it at all. I even tried a version of ideapad gaming that has the same motherboard and oddly enough it appears in the image with that BIOS. But the keyboard doesn't work.Leave a comment:
Attached FilesLeave a comment:
friend, you can clear the ME of this BIOS and put the DMI of my notebook ??Attached FilesLeave a comment:
You could have a Hardware Issue, or you maybe moved any component near by the BIOS Chip.
Create a New thread in the Hardware Forum:
https://www.badcaps.net/forum/forumdisplay.php?f=23Leave a comment:
I did everything right as it is in the post.
the problem is that it seems that the BIOS is still defectiveLeave a comment:
friend I just put new BIOS but even so it keeps turning on and getting the black screen.
Do you have any idea what it could be? because this happened when I updated his BIOS. when he restarted he turned on the leds and never again gave an image of anything.
I'm using a CH341 Programmer V1.43 my chip is a MX25L12872FM2I-10G Macronix
when I put it in the program it recognizes the normal chip, erases it, makes the recording successfully
I have no idea what it could be... And I don't understand anything about BIOS, so it would be just taking this BIN image and having it programmed right?
Is there any chance the BIOS is still corrupted with something?
before the 58ww version that did this. it was working properly in 52WW version
https://www.badcaps.net/forum/showpo...40&postcount=2Leave a comment:
before the 58ww version that did this. it was working properly in 52WW versionLast edited by Sergio06; 03-08-2023, 07:50 AM.Leave a comment:
If your Problem is related to BIOS Issues, this file should fix it.Leave a comment:
Serial Number:PE07PV5N
Machine Type Model:82CF0004BR
Legion 5-15IMH05HAttached FilesLast edited by Sergio06; 03-08-2023, 05:38 AM.Leave a comment:
DMI 532000 - 533FFFAttached FilesLeave a comment:
Dear All
i need clean my BIOS DUMP
Legion 5-15IMH05H
SN: PF2YZG35
MTM: 81Y600SAUS
Attached :Attached FilesTags: None
by AhariHi all,
I...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
I need bios dump for Legion Go 8APU1 bios dump.
There is a bios on the Lenovo website, but only an update.-
- Loading...
